Author Topic: turn system sound volume up  (Read 4554 times)
BillZndl
« on: August 12, 2015, 11:55:00 AM »
Autocad 2012, VS2010 net 3.5,C# Windows 7
Anyone know how to access/change the computer speaker volume from C# directly?
I've searched extensively and everything I find creates a form with sliders.
I'd like to turn the volume to full before I play an .mp3 file from a .dll netloaded into AutoCAD.
This code works for the instantiated media player but doesn't affect the speaker sound of the computer.
Trying to figure out if there's a way to get the handle for the main volume.
Code - C#: [Select]
  1. namespace Whistles
  2. {
  3.
  4.     public class Whistle
  5.     {
  6.         public Whistle()
  7.         {
  8.         }
  9.
  10.         [CommandMethod("Whistles", CommandFlags.Session)]
  11.
  12.         public void PlayFile()
  13.         {
  14.
  15.             System.Audio.Volume = 100; // for 100%
  16.
  17.             MediaPlayer mp = new MediaPlayer();
  18.             mp.Open(new Uri(@"G:/AutoCAD2012Support/VisualStudio2010/WhistleSounds/Samsung_whistle_ringtone.mp3", UriKind.Absolute));
  19.             mp.Play();
  20.
  21.             System.Audio.Volume = 14;
  22.         }
  23.     }
  24. }
  25.
  26. namespace System
  27. {
  28.     public partial class Audio
  29.     {
  30.         [DllImport("winmm.dll")]
  31.         static extern int waveOutGetVolume(IntPtr hwo, out uint dwVolume);
  32.
  33.         [DllImport("winmm.dll")]
  34.         static extern int waveOutSetVolume(IntPtr hwo, uint dwVolume);
  35.
  36.         public static int Volume
  37.         {
  38.             get
  39.             {
  40.                 uint CurrVol = 100;
  41.                 ushort CalcVol = (ushort)(CurrVol & 0x0000ffff);
  42.                 return CalcVol;/// (ushort.MaxValue / 100);
  43.             }
  44.             set
  45.             {
  46.                 int NewVolume = value;
  47.                 uint NewVolumeAllChannels = ((uint)NewVolume & 0x0000ffff);
  48.                 waveOutSetVolume(IntPtr.Zero, NewVolumeAllChannels);
  49.             }
  50.         }
  51.     }
  52. }
  53.
BlackBox
Re: turn system sound volume up
« Reply #1 on: August 12, 2015, 12:20:48 PM »
If rolling your own implementation instead of using something like NirCmd, P/Invoke User32, and use either SendMessageW() + VOLUME_UP const, or KeyBd_Event() + Keys.VolumeUp enum.
BillZndl
« Reply #2 on: August 12, 2015, 04:58:14 PM »
Yes, I seem to be having some progress.
I think I am getting the correct window handle of the main window.
I am not sure if I am getting the correct msg.
still researching.  :|
Code - C#: [Select]
  1. public class Whistle
  2.     {
  3.         public Whistle()
  4.         {
  5.         }
  6.
  7.         [CommandMethod("Whistles", CommandFlags.Session)]
  8.
  9.         public void PlayFile()
  10.         {
  11.
  12.             IntPtr hWnd = Process.GetProcessesByName("explorer")[0].MainWindowHandle;
  13.
  14.             uint msg = 0x319;//<<< not sure about this one.
  15.
  16.             UIntPtr VOLUME_UP = (UIntPtr)0x319; //0xA0000;
  17.             IntPtr lParam = IntPtr.Zero;
  18.
  19.             IntPtr e = DirectVolume.VolUp.SendMessageW(hWnd, msg, VOLUME_UP, lParam);
  20.
  21.             System.Windows.MessageBox.Show( "Value of e : " + e.ToString());
  22.
  23.             if (e.ToInt32() > 0)
  24.             {
  25.                 MediaPlayer mp = new MediaPlayer();
  26.                 mp.Open(new Uri(@"G:/AutoCAD2012Support/VisualStudio2010/WhistleSounds/Samsung_whistle_ringtone.mp3", UriKind.RelativeOrAbsolute));
  27.                 mp.Play();
  28.             }
  29.         }
  30.     }
  31. }
  32. namespace DirectVolume
  33. {
  34.     public partial class VolUp
  35.     {
  36.
  37.         [DllImport("User32.dll")]
  38.         public static extern IntPtr FindWindow(String sClassName, String sAppName);
  39.         [DllImport("User32.dll")]
  40.         public static extern IntPtr SendMessageW(IntPtr hWnd, uint msg, UIntPtr VOLUME_UP, IntPtr lParam);
  41.
  42.
  43.     //P/Invoke User32, and use either SendMessageW() + VOLUME_UP const, or KeyBd_Event() + Keys.VolumeUp enum.
  44.     //const int VOLUME_UP = 0xA0000;
  45.     }
  46. }
  47.
  48.
nobody
  • .net stuff
« Reply #3 on: August 12, 2015, 09:46:43 PM »
Haha...this could be pretty messed up to do to fellow workers
BlackBox
« Reply #4 on: August 13, 2015, 01:34:47 AM »
nobody
  • .net stuff
« Reply #5 on: August 13, 2015, 02:22:36 AM »
haha...that's great stuff
BillZndl
« Reply #6 on: August 13, 2015, 06:30:59 AM »
My primary goal wasn't to "mess" with co-workers but......
There is a guy that uses a ring tone that we all find annoying.
So I thought if I could make a few machines around him occasionally play the same ringtone,
it may help him look for another tone to use.
Trouble is, the .mp3's are barely audiable when a machine is on 15%-20%,
which most of the machines are becaus the beeps are much louder at that setting,
so I need to turn up the volume and down again after playing the mp3.
BlackBox
« Reply #7 on: August 13, 2015, 08:33:56 AM »
Perhaps a simpler way of going about this, depending on your domain credentials, is to simply use PowerShell... See this thread for the Set-Speaker calls, among other options:
http://stackoverflow.com/questions/21355891/change-audio-level-from-powershell
... One member even wrote his own PowerShell CmdLet, which exposes:
  • Get-DefaultAudioDevice
  • Get-AudioDeviceList
  • Set-DefaultAudioDevice [-Index] <Int>
  • Set-DefaultAudioDevice [-Name] <String>
  • Set-DefaultAudioDevice [-InputObject] <AudioDevice>
  • Set-DefaultAudioDeviceVolume -Volume <float>
  • Get-DefaultAudioDeviceVolume
  • Set-DefaultAudioDeviceMute
  • Write-DefaultAudioDeviceValue [-StreamValue]
http://www.automatedops.com/projects/windowsaudiodevice-powershell-cmdlet/
BillZndl
« Reply #8 on: August 13, 2015, 09:50:43 AM »
Yeah, well....
This might be a bit over my head and permissions, don't know.
I'll give it a try if it slows up around here.
Thanks!
Bill
dgorsman
« Reply #9 on: August 13, 2015, 10:19:36 AM »
Until somebody has their headphones on and you give them temporary hearing loss.  Stuff like this rarely ends well.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
BlackBox
« Reply #10 on: August 13, 2015, 12:15:23 PM »
... Stuff like this rarely ends well.
This.
« Reply #11 on: August 13, 2015, 01:57:53 PM »
This.
Yep, as in most games a poke in the eye with a stick spoils everyone's fun  :|
BillZndl
« Reply #12 on: August 14, 2015, 07:38:33 AM »
Well,
it was kinda fun to see the guy grab for his cell phone when I played his ringtone from my machine with the volume up.
(about 6 of us in an open room divided with cubicals and music playing so it's not easy to tell where it's coming from).
He'll figure it out if I do it too much, so maybe I'll put it on a timer so it happens when I'm not at my machine or better yet,
when I'm over talking to him.  :-D
