Author Topic: Select similar blocks which have different names  (Read 8482 times)
NICK_VNV
« on: June 26, 2015, 03:02:02 AM »
I have hundreds of drawings with thousands of anonymous blocks. There are many blocks which have same geometry but have different names, so i can't ssget' them as needed. All of them are in one layer. I'm trying to select similar ones and put them to their own layer.
Could someone help me or have any ideas on how to do this?
Example drawing is attached
Re: Select similar blocks which have different names
« Reply #1 on: June 26, 2015, 09:00:31 AM »
What version of cad do you have? Not sure when it was introduced but there is a SELECTSIMILAR command now.
NICK_VNV
« Reply #2 on: June 26, 2015, 01:06:09 PM »
I have SELECTSIMILAR command but it won't work because some blocks have different names. Did you tried open attached drawing?
Imagine it's like you draw 5 circles with same radius (other parameters may be the same also), but then you make 5 different blocks with unique names from each of them. SELECTSIMILAR would not recognize such blocks as similar.
For now I decided to write a lisp which will sort all anonymous blocks by comparing all their subentities. I think this may be a solution  :-D
« Last Edit: June 26, 2015, 02:28:46 PM by NICK_VNV »
« Reply #3 on: June 26, 2015, 02:36:45 PM »
So you got it handled ? .. Another idea might be to compare the area of the bounding box of each block. If you set the tolerance tight enough it should be fairly accurate I'd think.
« Last Edit: June 26, 2015, 02:49:41 PM by ronjonp »
NICK_VNV
« Reply #4 on: June 27, 2015, 01:42:35 AM »
Oh.. this should be much faster I think. Probability of existence of different blocks with the same bounding box should be very low. I'll check both methods next week.
Thanks for help! :-)
« Last Edit: June 27, 2015, 01:47:08 AM by NICK_VNV »
lamarn
« Reply #5 on: June 27, 2015, 05:24:02 AM »
It would really be a big help of there was a way to do a 'select similar' based on geometry or volume.
Revit has the ability to export family to block containing unique id names. Annoying and making dwg export huge.
Could it be done to replace then with one and the same. The only thing I am not able to do is to the good selecting in a quick way. Workaround would help. Thanks.
https://twitter.com/halammerts/status/577828905786163200
NICK_VNV
« Reply #6 on: June 29, 2015, 07:08:18 AM »
First try of selecting "similar" blocks by bounding box (with tolerance).
(defun blocks_select_same_bbox (fuzz / ent ss ss_lst size_x1 size_y1 size_x2 size_y2 ll1 ll2 ur1 ur2 new_ss)
 (setq ent (ssname (ssget "_:S" (list '(0 . "INSERT") )) 0))
 (vla-getboundingbox (vlax-ename->vla-object ent) 'll1 'ur1)
 (setq size_x1 (- (car (vlax-safearray->list ur1)) (car (vlax-safearray->list ll1))) )
 (setq size_y1 (- (cadr (vlax-safearray->list ur1)) (cadr (vlax-safearray->list ll1))) )
 (setq ss (ssget "_X" (list '(0 . "INSERT") )) )
 (setq ss_lst  (mapcar 'cadr (ssnamex ss)))
 (setq new_ss (ssadd))
 (foreach blk ss_lst
  (vla-getboundingbox (vlax-ename->vla-object blk) 'll2 'ur2)
  (setq size_x2 (- (car (vlax-safearray->list ur2)) (car (vlax-safearray->list ll2))) )
  (setq size_y2 (- (cadr (vlax-safearray->list ur2)) (cadr (vlax-safearray->list ll2))) )
  (if (and (< (abs(- size_x1 size_x2)) fuzz) (< (abs(- size_y1 size_y2)) fuzz))
   (setq new_ss (ssadd blk new_ss))
 );foreach
 (sssetfirst nil new_ss)
 (vl-cmdf "_regen")
 new_ss
Run:
(blocks_select_same_bbox 0.01)
But this method works only if rotation of entities was the same before they become a block, otherwise boundig box diffrers significant  :-(
So I'll check next method to compare subentities of blocks.
« Last Edit: June 29, 2015, 07:14:27 AM by NICK_VNV »
« Reply #7 on: June 29, 2015, 01:28:10 PM »
Here's a rough draft to get you started:
  1. ;; Select Similar Blocks  -  Lee Mac
  2.
  3. (defun c:ssb ( / blk def ent lst tmp )
  4.     (while
  5.         (progn (setvar 'errno 0) (setq blk (car (entsel "\nSelect block: ")))
  6.             (cond
  7.                 (   (= 7 (getvar 'errno))
  8.                     (princ "\nMissed, try again.")
  9.                 )
  10.                 (   (null blk) nil)
  11.                 (   (/= "INSERT" (cdr (assoc 0 (setq blk (entget blk)))))
  12.                     (princ "\nSelected object is not a block.")
  13.                 )
  14.             )
  15.         )
  16.     )
  17.     (if blk
  18.         (progn
  19.             (while (setq def (tblnext "block" (null def)))
  20.                 (setq ent (tblobjname "block" (cdr (assoc 2 def))))
  21.                 (while (setq ent (entnext ent))
  22.                     (setq tmp
  23.                         (cons
  24.                             (vl-sort
  25.                                 (apply 'append
  26.                                     (mapcar
  27.                                         (function
  28.                                             (lambda ( x )
  29.                                                 (if (and (/= 'ename (type (cdr x))) (not (member (car x) '(5))))
  30.                                                     (list x)
  31.                                                 )
  32.                                             )
  33.                                         )
  34.                                         (entget ent)
  35.                                     )
  36.                                 )
  37.                                '(lambda ( a b )
  38.                                     (if (= (car a) (car b))
  39.                                         (if (listp (cdr a))
  40.                                             (vl-some '< (cdr a) (cdr b))
  41.                                             (< (cdr a) (cdr b))
  42.                                         )
  43.                                         (< (car a) (car b))
  44.                                     )
  45.                                 )
  46.                             )
  47.                             tmp
  48.                         )
  49.                     )
  50.                 )
  51.                 (setq lst (cons (cons (assoc 2 def) (reverse tmp)) lst)
  52.                       tmp nil
  53.                 )
  54.             )
  55.             (setq blk (cdr (assoc (assoc 2 blk) lst)))
  56.             (sssetfirst nil
  57.                 (ssget "_X"
  58.                     (append '((0 . "INSERT") (-4 . "<OR"))
  59.                         (mapcar '(lambda ( x ) (cons 2 (LM:escapewildcards (cdar x))))
  60.                             (vl-remove-if-not
  61.                                 (function
  62.                                     (lambda ( x )
  63.                                         (vl-every
  64.                                             (function
  65.                                                 (lambda ( y )
  66.                                                     (vl-some
  67.                                                         (function
  68.                                                             (lambda ( z )
  69.        (vl-every
  70.        (function
  71.        (lambda ( a b )
  72.        (and (= (car a) (car b))
  73.        (or (and (member (type (cdr a)) '(real list)) (equal (cdr a) (cdr b) 1e-8))
  74.        (= (cdr a) (cdr b))
  75.        )
  76.        )
  77.        )
  78.        )
  79.        y z
  80.        )
  81.                                                             )
  82.                                                         )
  83.                                                         (cdr x)
  84.                                                     )
  85.                                                 )
  86.                                             )
  87.                                             blk
  88.                                         )
  89.                                     )
  90.                                 )
  91.                                 lst
  92.                             )
  93.                         )
  94.                        '((-4 . "OR>"))
  95.                     )
  96.                 )
  97.             )
  98.         )
  99.     )
  100.     (princ)
  101. )
  102.
  103. ;; Escape Wildcards  -  Lee Mac
  104. ;; Escapes wildcard special characters in a supplied string
  105.
  106. (defun LM:escapewildcards ( str )
  107.     (vl-list->string
  108.         (apply 'append
  109.             (mapcar
  110.                '(lambda ( c )
  111.                     (if (member c '(35 64 46 42 63 126 91 93 45 44))
  112.                         (list 96 c)
  113.                         (list c)
  114.                     )
  115.                 )
  116.                 (vl-string->list str)
  117.             )
  118.         )
  119.     )
  120. )
  121.
EDIT: typo fixed.
« Last Edit: June 29, 2015, 06:27:09 PM by Lee Mac »
« Reply #8 on: June 29, 2015, 02:41:04 PM »
That's pretty slick Lee :)
lamarn
« Reply #9 on: June 29, 2015, 05:34:15 PM »
I have tried both routines.
Thank you both for these fine codes, Lee Macs & Nick
Look like Nicks code works better and faster if I use it on a bunch of revit output.
This can work but now I found out that Revit produces very odd placed block definition.
The same 'looking' blocks fro Revit, as in AutoCAD you would model them, have different names but ALL WITH SAME ORIGIN .
To me this again shows how DWG from Revit is .. (hard to handle..)
« Last Edit: June 29, 2015, 05:38:09 PM by lamarn »
« Reply #10 on: June 29, 2015, 06:30:32 PM »
Cheers Ron  :-)
« Reply #11 on: June 29, 2015, 06:47:11 PM »
Yes it is.
... though I doubt a beginner will be able to follow the functionality  :|
NICK_VNV
« Reply #12 on: June 30, 2015, 02:17:22 AM »
Awesome Lee, it's a big help to "get started"  :-) Thanks!
HasanCAD
« Reply #13 on: June 30, 2015, 04:29:59 AM »
LEE
Try to sellect thisblock (fist ar right) the lisp'll select 2 types
« Reply #14 on: June 30, 2015, 02:39:43 PM »
You're welcome!  :-)
LEE
Thanks Hasan - here is a much better version:
  2.
  4.     (while
  6.             (cond
  9.                 )
  13.                 )
  14.             )
  15.         )
  16.     )
  17.     (if blk
  18.         (progn
  21.                       tmp nil
  22.                 )
  23.                 (while (setq ent (entnext ent))
  24.                     (setq tmp
  25.                         (append tmp
  26.                             (vl-remove-if
  27.                                '(lambda ( x ) (or (= 'ename (type (cdr x))) (member (car x) '(5))))
  28.                                 (entget ent)
  29.                             )
  30.                         )
  31.                     )
  32.                 )
  33.                 (setq lst
  34.                     (cons
  35.                         (cons (assoc 2 def)
  36.                             (vl-sort tmp
  39.                                         (if (listp (cdr a)) (vl-some '< (cdr a) (cdr b)) (< (cdr a) (cdr b)))
  40.                                         (< (car a) (car b))
  41.                                     )
  42.                                 )
  43.                             )
  44.                         )
  45.                         lst
  46.                     )
  47.                 )
  48.             )
  49.             (setq blk (cdr (assoc (assoc 2 blk) lst)))
  50.             (sssetfirst nil
  51.                 (ssget "_X"
  52.                     (append '((0 . "INSERT") (-4 . "<OR"))
  53.                         (mapcar '(lambda ( x ) (cons 2 (LM:escapewildcards (cdar x))))
  54.                             (vl-remove-if-not
  55.                                '(lambda ( x )
  56.                                     (vl-every
  57.                                        '(lambda ( a b )
  58.                                             (and (= (car a) (car b))
  59.                                                  (or (and (member (type (cdr a)) '(real list)) (equal (cdr a) (cdr b) 1e-8))
  60.                                                      (= (cdr a) (cdr b))
  61.                                                  )
  62.                                             )
  63.                                         )
  64.                                         blk (cdr x)
  65.                                     )
  66.                                 )
  67.                                 lst
  68.                             )
  69.                         )
  70.                        '((-4 . "OR>"))
  71.                     )
  72.                 )
  73.             )
  74.         )
  75.     )
  76.     (princ)
  77. )
  78.
  79. ;; Escape Wildcards  -  Lee Mac
  80. ;; Escapes wildcard special characters in a supplied string
  81.
  82. (defun LM:escapewildcards ( str )
  83.     (vl-list->string
  84.         (apply 'append
  85.             (mapcar
  86.                '(lambda ( c )
  87.                     (if (member c '(35 64 46 42 63 126 91 93 45 44))
  88.                         (list 96 c)
  89.                         (list c)
  90.                     )
  91.                 )
  92.                 (vl-string->list str)
  93.             )
  94.         )
  95.     )
  96. )
  97.
