Author Topic: polygonal MVIEW printing  (Read 2193 times)
Andrea
« on: April 25, 2005, 06:14:12 PM »
Hi all,
I have a little big problem..
a printing problem..
When i'm trying to print a drawing in PaperSpace with 1 Mview.
(rectangular MVIEW)
it take 2 min. and the drawing is printing..
But in the same drawing...i f i delete the (rectangular MVIEW)
and replace with a customised MVIEW (Polygonal) or make VPclip.
and trying to print this drawing..
the drawing take over 20 min to print....!!!
Is this is normal ??
i hope not..
I can't see any patch or update for this...
any suggestion ?
thanks.
Keep smile...
CADaver
« Reply #1 on: April 26, 2005, 11:23:30 AM »
Nope never had that problem and use VPCLIP often.  Check your plotter drivers for the latest.
t-bear
« Reply #2 on: April 26, 2005, 01:41:53 PM »
We use them allthe time here too and have never experienced what you describe....Sorry Andrea, but I haven't a clue.....wish I could help!
daron
« Reply #3 on: April 26, 2005, 03:09:21 PM »
Sorry, I never had that problem either. Are you using 2006? Could be a new bug altogether.
Andrea
« Reply #4 on: April 27, 2005, 12:27:54 PM »
hmmm....
this is strange...
But maybe isthe driver...
we use HP designJET800 (color printer)
andwe have made tests with different drivers....
but same thing.
Keep smile...
daron
« Reply #5 on: April 27, 2005, 02:08:40 PM »
What version of ACAD are you using?
Crank
« Reply #6 on: April 27, 2005, 10:03:45 PM »
The plotsize doubles with custom viewports, so I think it's a memory issue.
Did you try a smal drawing if it has the same problem?
Andrea
« Reply #7 on: April 28, 2005, 12:52:39 PM »
yes....
using AutoCAD2004,...
and do same thing with small drawing...
(double size)...
so what can i do for this ??
Keep smile...
