Author Topic: Reloading a specific xref on a bunch of draings  (Read 2269 times)
diego65
  • Learning LISP is a cool thing
« on: March 24, 2015, 01:28:36 PM »
Once again I need your guys help.
What I am looking for is to be able to reload an unloaded reference file in a bunch of drawings located within a directory.
The code below is what I have but seems that I am missing something.
Any help will be very much appreciated it.
(defun c:reload ( )
    (LM:ODBX
        (function
            (lambda ( doc / xref name)
                ;(vlax-for lay (vla-get-layers doc)
      (vlax-for xref (vla-get- xref name)
        (if (wcmatch (strcase (vla-get-name xref)) "*|Road_Construction_City")
      (vla-put- reload xref :vlax-true)
        nil t
Thank you…
Re: Reloading a specific xref on a bunch of draings
« Reply #1 on: March 24, 2015, 01:36:00 PM »
If I recall correctly, xrefs are not available/loaded when interfacing with a drawing through ObjectDBX - you may need to use a Script to perform this task.
diego65
« Reply #2 on: March 24, 2015, 01:51:04 PM »
Thank you Lee Mac,
Can you help me with that please?
Thank you...
« Reply #3 on: March 24, 2015, 01:53:07 PM »
If you write the code to reload the xref in a single drawing, you can use my old Script Writer program to evaluate your xref program across several drawings.
diego65
« Reply #4 on: March 24, 2015, 02:00:40 PM »
Thank you Lee Mac,
You are talking to a rock here and I am Man U fan not West Ham... :)...
How deos this scrip works? I load as a .lsp file?
« Reply #5 on: March 24, 2015, 03:22:12 PM »
Just a quick glance .. but this will always be false:
cadtag
« Reply #6 on: March 25, 2015, 02:08:09 PM »
the question is... Why?
xref's will be reloaded anytime the drawing is opened or edited.  An plotting/publishing counts as opening.
diego65
« Reply #7 on: April 01, 2015, 04:46:39 PM »
The reason is that our with our drawing’s template, we add most of our Digital Stamps such as Issue for construction, Preliminary not for construction and such.
All of these stamps are unloaded in our template but when drawings are to be sent out, we need to show of them depend on the stage of the project, going to every drawing and reload it manually is time consuming.
