Author Topic: 2012 DWG open edit close problem  (Read 2610 times)
David Bethel
« on: January 16, 2015, 03:26:38 PM »
Greetings.
I now remember why I don't like the newer versions of ACAD  yuck!
I need to open all files in a given directory, load a .lsp, issue a autolisp call, save the changes, close the dwg.
I will use DosLIB to obtain the directory and file info
In earlier version it is pretty straight forward.
I have to make this work in 2012...
psudo code
  Get user input of the directory work with ( i can get this from getfiled )
  Write to a script file for each dwg;
  _.OPEN command
  dwg name
 (load "myfoo")
 (my_foo)
 _.CLOSE command
Then the user can manually run the .SCR file ( multiple times if necessary )
I've found some info on the sysvar SDI.  I'm really not sure if this is way to go.  When it errors out, it really doesn't give good info
By hand i can get 'CLOSE does not work with SDI 1'
By hand open does not need SDI =1, but it does in a script or code ?
How do you guys approach this scenario ?
Script so far ( not working )
(if (getvar "SDI") (setvar "SDI" 1))
(if (/= (getvar "DBMOD") 0)
    (command "_.OPEN" "_Yes" "C:/ACADPROJ/TO/PARENT/GCIR001E")
    (command "_.OPEN" "C:/ACADPROJ/TO/PARENT/GCIR001E"))
(if (getvar "SDI") (setvar "SDI" 0))
(load "NW_FOO")
(nw_foo "C:/ACADPROJ/TO/CHILD/")
    (command "_.CLOSE" "_N")
    (command "_.CLOSE"))
    (command "_.OPEN" "_Yes" "C:/ACADPROJ/TO/PARENT/GCIR001P")
    (command "_.OPEN" "C:/ACADPROJ/TO/PARENT/GCIR001P"))
(load "NW_FOO")
« Last Edit: January 16, 2015, 03:30:03 PM by David Bethel »
R12 Dos - A2K
Re: 2012 DWG open edit close problem
« Reply #1 on: January 16, 2015, 03:35:45 PM »
One thing I notice is your filenames do not have the ".dwg"
David Bethel
« Reply #2 on: January 16, 2015, 04:35:26 PM »
I didn't think that .dwg was ever required .  Am I that far behind times ?
Hopefully there is a fancy dancy vl call that works like the old days
Thanks!  -David
R12 Dos - A2K
« Reply #3 on: January 16, 2015, 05:06:52 PM »
Here is how one section of a script I have used in the past on 2012 looks like, the rest is the same just a different drawing name.  Some of the commands are native commands and others are lisp commands that load per an .mnl file.
_.open
"H:\Work\3M\Kelli\Irvine\Flexpack\aps\12-2718-5160-7_019.dwg"
(vlax-for lo (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-Acad-Object))) (if (/= (vla-get-Name lo) "Model") (vla-Delete lo)))
measurement 0
insunits 1
ctab layout1
.-insert "C:\ACADSUPP2011\TEMPLATE\3M-TITLEBLOCK-E.dwg" 0,0 1 1 0
.explode (entlast)
_3MTitleLayers P
_.mview 0.7628,33.1694 43.2372,5.1613
_.mspace
_.plan _world
_.zoom .95x
_.pspace
_.-layer new Defpoints
.chprop (entlast)  Layer Defpoints
_.zoom extents
updnum
_.qsave
_.close
David Bethel
« Reply #4 on: January 17, 2015, 08:53:37 AM »
I did away with all (command  open qsave close ) calls and went back to the native commands in the script and got it to work.
Now how to figure out a redefine block scenario using insert block=block without using a (command) to exit as it causes the script stop processing..
Thanks!  -David
R12 Dos - A2K
« Reply #5 on: January 17, 2015, 08:57:06 AM »
Insert & erase  :wink:
David Bethel
« Reply #6 on: January 17, 2015, 10:24:39 AM »
Yes Lee, that's where I'm at. If the child has ATTRIButes, its a bit more complicated.
If you use:
(while (> (getvar "CMDACTIVE) 0)
         (command ""))
The script stops processing.  And you have manually type RESUME
Still, we're getting there.  Thanks!  -David
R12 Dos - A2K
roy_043
  • BricsCAD 18
« Reply #7 on: January 17, 2015, 10:30:06 AM »
(setvar 'attreq 0)
David Bethel
« Reply #8 on: January 17, 2015, 12:27:06 PM »
(setvar 'attreq 0)
Wow!  didn't about that 1 !  Great !  -David
R12 Dos - A2K
