Author Topic: Creating dynamic blocks  (Read 2852 times)
Tasaq
« on: January 14, 2015, 01:40:27 PM »
I need to create a BlockReference that will have DynamicBlockTableRecord containing ExtesionDictionary with ACAD_ENHANCEDBLOCK (so I have that triangular girp visible after inserting block). I know the logic behind EvalGraph so it should be easy for me to edit it, but I have no idea how to create and add it to the dictionary. Is there any way to achieve this?
BillZndl
Re: Creating dynamic blocks
« Reply #1 on: January 14, 2015, 02:06:00 PM »
Tasaq
« Reply #2 on: January 15, 2015, 11:14:19 AM »
I don't see there anythng I could use. Most of the code there uses already existing blocks or inserts it from dwg file.
BillZndl
« Reply #3 on: January 15, 2015, 01:00:25 PM »
I don't know if it's possible, I've never done it myself.
http://forums.autodesk.com/t5/net/definition-of-dynamic-blocks-with-net-api/td-p/2377920
Maybe someone else can chime in that knows more.
Tasaq
« Reply #4 on: January 15, 2015, 01:36:37 PM »
I also stumbled upon this post today. It seems it's not possible with current API. It's a shame, it would give so many interesting possibilities.
dgorsman
« Reply #5 on: January 15, 2015, 03:06:58 PM »
Creating anything more than a simple block would be easier to do manually, given all the tools and interfaces are already provided inside AutoCAD.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
mohnston
  • CAD Programmer
« Reply #6 on: January 22, 2015, 01:06:41 AM »
You can't create a dynamic block definition in code but can manipulate dynamic properties of existing blocks
CAD Programming Solutions
