Author Topic: Make an argment optional?  (Read 2139 times)
TimSpangler
  • CAD Naked!!
« on: April 19, 2005, 02:07:16 PM »
How is this done?  I have a routine:
(defun FilterList (AList Filter  / TruncString )
(if (not Filter)
(alert "No Filter Set")
(setq FilterList '())
(foreach Obj Alist
(setq TruncString(substr(nth 0(TGS:StringToList(cdr Obj)";"))3 4))
(if (= (strcase Filter) TruncString)
(setq FilterList (cons Obj FilterList))
FilterList
that take 2 arguments but I only really need the first one all of the time.  If the second one is supplied then I want to use it.  How do I go about this?
BTW: This routine takes a list and a filter and checks the filter against a certian thing in the list if it matches the filter it adds it to a new list which will be sent to a list box.  The reason for the optional argument is if no filter is suppied I want the whole list sen to the listbox
ACA 2015 - Windows 7 Pro
« Reply #1 on: April 19, 2005, 02:08:58 PM »
Pass but one argument, a list. Need more info than this?
« Reply #2 on: April 19, 2005, 02:53:45 PM »
Some ideas ... coded blind / not tested, as I don't have one of the functions you're calling.
(defun FilterList ( arguments / filter result )
    ;;  first item in arguments is alist
    ;;  second item in arguments is filter
        (   (setq filter (cadr arguments))
            (foreach item (car arguments) ;; alist (implied)
                    (eq (strcase filter)
                        (strcase
                            (substr
                                (car
                                    (TGS:StringToList
                                        (cdr item)
                                3
                                4
                    (setq result
                        (cons
                            item
                            result
            ;;  even though you can have a local variable
            ;;  named the same as the function hosting it
            ;;  I think this is a better tact
            result
        ((alert "No Filter Set"))
;;  formerly you'd call FilterList thusly
(FilterList alist filter)
;;  now like so
(FilterList (list alist filter))
;;  or
(FilterList (list alist))
