Author Topic: Fast Demolition Code  (Read 8217 times)
cmwade77
Re: Fast Demolition Code
« Reply #15 on: December 02, 2014, 05:41:56 PM »
Lee, I am starting to wonder if I would ever finish a routine without your help.
I'm delighted to be able to assist you  :-)
My advice would be:
Change Lee's code so that it returns nil if there is no outline. Whenever you call LM:outline you can then check for a nil return value and act accordingly.
...LM:Outline doesn't work with empty selection sets.
Good catch roy -
I agree that the function should be modified to return nil rather than an empty selection set if the outline cannot be generated, however, I don't think the function should be modified to accept a null selection set, as I feel this should be the responsibility of the caller.
Lee, I agree completely, I am modifying my routine to make sure that there is not a null selection set.
« Last Edit: December 02, 2014, 06:21:38 PM by cmwade77 »
« Reply #16 on: December 02, 2014, 06:28:02 PM »
Looks good Chris - well done!  :-)
cmwade77
« Reply #17 on: December 02, 2014, 06:47:07 PM »
Ok, I have resolved most of the bugs, but I am still having some issues where empty spaces are created when there are overlapping areas, please see attached image for example.
Here is the current code:
;* FD.lsp *
;* Fast Demolition *
;* Quickly adds demolition hatching by selecting objects *
;* Version 3.0 *
;* Chris Wade *
;* 12/01/2014 *
;* - Complete rewrite. *
;* - Faster drawing of demolition hatching. *
;* - Hatching is now more reliable. *
;* - Hatching now only covers what is needed. *
;* Version 2.0   *
;* Chris Wade   *
;* 08/04/2011   *
;* - Completely rewritten from scratch. *
(defun c:FD (/ *thisdrawing* *ACAD_LAYERS* Ct SS Obj ObjEnt Obj1 Obj2 Obj1Ent Obj2Ent Obj1End Obj2End Obj3 Obj3Ent Obj4 Obj4Ent Obj7 Obj7Ent StopLoop Tst h_ss f_SS L_SS fh_SS retCoordA retCoordB TM)
;Supporting Functions
;;-----------------------=={ Outline Objects  }==-----------------------;;
;;  This program enables the user to generate one or more closed        ;;
;;  polylines or regions outlining all objects in a selection.          ;;
;;  Following a valid selection, the program calculates the overall     ;;
;;  rectangular extents of all selected objects and constructs a        ;;
;;  temporary rectangular polyline offset outside of such extents.      ;;
;;  Using a point located within the offset margin between the extents  ;;
;;  of the selection and temporary rectangular frame, the program then  ;;
;;  leverages the standard AutoCAD BOUNDARY command to construct        ;;
;;  polylines and/or regions surrounding all 'islands' within the       ;;
;;  temporary bounding frame.                                           ;;
;;  Author:  Lee Mac, Copyright © 2014  -  www.lee-mac.com              ;;
;;  Version 1.0    -    2014-11-30                                      ;;
;;  First release.                                                      ;;
(defun c:outline ( / *error* sel )
    (defun *error* ( msg )
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
    (if (setq sel (ssget))
            (LM:startundo (LM:acdoc))
            (LM:outline sel)
;; Outline Objects  -  Lee Mac
;; Attempts to generate a polyline outlining the selected objects.
;; sel - [sel] Selection Set to outline
;; Returns: [sel] A selection set of all objects created
(defun LM:outline ( sel / app are box cmd dis enl ent lst obj rtn tmp )
    (if (setq box (LM:ssboundingbox sel))
            (setq app (vlax-get-acad-object)
                  dis (/ (apply 'distance box) 20.0)
                  lst (mapcar '(lambda ( a o ) (mapcar o a (list dis dis))) box '(- +))
                  are (apply '* (apply 'mapcar (cons '- (reverse lst))))
                  dis (* dis 1.5)
                  ent
                (entmakex
                    (append
                       '(   (000 . "LWPOLYLINE")
                            (100 . "AcDbEntity")
                            (100 . "AcDbPolyline")
                            (090 . 4)
                            (070 . 1)
                        (mapcar '(lambda ( x ) (cons 10 (mapcar '(lambda ( y ) ((eval y) lst)) x)))
                           '(   (caar   cadar)
                                (caadr  cadar)
                                (caadr cadadr)
                                (caar  cadadr)
            (apply 'vlax-invoke
                (vl-list* app 'zoomwindow
                    (mapcar '(lambda ( a o ) (mapcar o a (list dis dis 0.0))) box '(- +))
            (setq cmd (getvar 'cmdecho)
                  enl (entlast)
                  rtn (ssadd)
            (while (setq tmp (entnext enl)) (setq enl tmp))
            (setvar 'cmdecho 0)
            (command
                "_.-boundary" "_a" "_b" "_n" sel ent "" "_i" "_y" "_o" "_p" "" "_non"
                (trans (mapcar '- (car box) (list (/ dis 3.0) (/ dis 3.0))) 0 1) ""
            (while (< 0 (getvar 'cmdactive)) (command ""))
            (entdel ent)
            (while (setq enl (entnext enl))
                (if (and (vlax-property-available-p (setq obj (vlax-ename->vla-object enl)) 'area)
                         (equal (vla-get-area obj) are 1e-4)
                    (entdel enl)
                    (ssadd  enl rtn)
            (vla-zoomprevious app)
            (setvar 'cmdecho cmd)
            (if (> (sslength rtn) 0);Code added by Chris Wade to return nill if there are no objects
            rtn
            nil
;; Selection Set Bounding Box  -  Lee Mac
;; Returns a list of the lower-left and upper-right WCS coordinates of a
;; rectangular frame bounding all objects in a supplied selection set.
;; s - [sel] Selection set for which to return bounding box
(defun LM:ssboundingbox ( s / a b i m n o )
    (repeat (setq i (sslength s))
            (and
                (setq o (vlax-ename->vla-object (ssname s (setq i (1- i)))))
                (vlax-method-applicable-p o 'getboundingbox)
                (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list o 'a 'b))))
            (setq m (cons (vlax-safearray->list a) m)
                  n (cons (vlax-safearray->list b) n)
    (if (and m n)
        (mapcar '(lambda ( a b ) (apply 'mapcar (cons a b))) '(min max) (list m n))
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(vl-load-com) (princ)
;;                             End of File                              ;;
;End of Supporting Functions
(setq *thisdrawing* (vla-get-activedocument (vlax-get-acad-object))
  *ACAD_LAYERS* (vla-get-layers *thisdrawing*)
(vla-startundomark *thisdrawing*)
(setq Scale (* 0.5 (getvar "Dimscale"))
  Odist (* 0.0625 (getvar "Dimscale"))
(while (not StopLoop)
(while (not SS)
(princ "\rSelect objects to demolish: ")
(setq SS (ssget))
(setq Tm (getvar "Tilemode"))
(if (= Tm 0)
(setvar "tilemode" 1)
(setq Ct 0
  SelectionLength (sslength SS)
  h_SS (ssadd)
  f_SS (ssadd)
(while (and (/= SS nil) (< Ct SelectionLength));Process open Plines & Blocks first
(setq Obj (vlax-ename->vla-object (ssname SS Ct))
  ObjName (vla-get-objectname Obj)
; (princ "\n")(princ ObjName)
((= ObjName "AcDbPolyline")
((= (vla-get-closed Obj) :vlax-false)
(vlax-invoke Obj 'Offset ODist)
(setq Obj1Ent (entlast)
  Obj1 (vlax-ename->vla-object Obj1Ent)
(vlax-invoke Obj 'Offset (* ODist -1))
(setq Obj2Ent (entlast)
  Obj2 (vlax-ename->vla-object Obj2Ent)
(setq Obj1End (vlax-curve-getendpoint Obj1)
  Obj2End (vlax-curve-getendpoint Obj2)
(vla-put-constantwidth Obj1 0)
(vla-put-constantwidth Obj2 0)
(command "._pline" Obj1End Obj2End "")
(setq Obj4Ent (entlast))
(setq OldPeditAccept (getvar "peditaccept"))
(setvar "peditaccept" 1)
(command "._pedit" "M" Obj4Ent Obj1Ent Obj2Ent "" "j" "0" "c" "")
(setvar "peditaccept" OldPeditAccept)
(setq Obj2Ent (entlast))
(setq Obj2 (vlax-ename->vla-object Obj4Ent))
(ssadd Obj2Ent h_SS)
(if (not (vlax-erased-p Obj1))
(vla-delete Obj1)
(T
(setq Obj7Ent (ssname SS Ct)
  Obj7 (vlax-ename->vla-object Obj7Ent)
(vlax-invoke Obj7 'Offset (* ODist -1))
((= ObjName "AcDbLine")
(vla-delete Obj1)
(T
(ssadd (ssname SS Ct) f_SS)
(setq ct (+ ct 1))
);End While
(if (/= f_SS nil)
(if (> (sslength f_ss) 0)
(setq L_ss (LM:Outline f_SS)
      ct 0)
(if (/= L_ss nil)
(while (< Ct (sslength L_ss))
(setq Obj7Ent (ssname L_ss ct)
(if (not (vlax-erased-p Obj7))
(vla-delete Obj7)
(setq Ct (+ ct 1))
(if (> (sslength h_SS) 0)
(setq fh_SS (LM:Outline h_SS))
(if (/= fh_SS nil)
(command "._-bhatch" "s" fh_SS "" "P" "Ansi31" scale "0" "")
(setq Obj3Ent (entlast)
  Obj3 (vlax-ename->vla-object Obj3Ent)
((not (tblsearch "LAYER" "$DEMOHATCH"))
(setq NewLayer (vla-add *ACAD_LAYERS* "$DEMOHATCH"))
(vla-put-color NewLayer 8)
((= (getvar "pstylemode") 0)
(vla-put-plotstylename NewLayer "highlight")
(vla-put-layer Obj3 "$DEMOHATCH")
(command "._erase" fh_SS "")
(alert "Demolition Hatching for selected objects could not be drawn automatically")
(command "._erase" h_SS "")
(if (/= (getvar "Tilemode") TM)
(setvar "tilemode" tm)
(setq SS nil)
(vla-endundomark *thisdrawing*)
roy_043
  • BricsCAD 18
« Reply #18 on: December 03, 2014, 04:33:04 AM »
... I don't think the function should be modified to accept a null selection set, as I feel this should be the responsibility of the caller.
I understand the fundamental issue that underlies your statement, but in this case I disagree. An example to clarify my view: A function taking a string as its single argument should fail when applied to an integer. But not when the argument is an empty string.
Having said that, I am quite sure that not all of my code complies with this ideal standard.
