Author Topic: Problem with dynamic Block and linear parametar  (Read 4165 times)
todor
  • Mosquito
« on: September 09, 2014, 06:24:52 AM »
regards,
in the drawing have two visibility parameters + -30 and + -15.
When the parameter is + -15 active displacement to the left of the parameter of the linear distance between the two lines is also ranked good
When the parameter is + -30 active displacement to the left of the parameter of the linear distance between the two lines is not good
Where is the problem ...
« Last Edit: September 09, 2014, 06:44:42 AM by todor »
Re: Problem with dynamic Block and linear parametar
« Reply #1 on: September 09, 2014, 10:17:11 AM »
Perhaps if you explained how the block is to be used?
Is the user to enter a road way width?
todor
  • Mosquito
« Reply #2 on: September 09, 2014, 03:23:59 PM »
Width of times it gets over stretch dynamic team.
When you open a drawing road width is 8.1 meters, if you want to be for example 10 meters, width of the road is not well listed.
Of course this is only valid if enabled visibiliti parametar + -30, while the involved parameters + -15 everything is ok.
