Author Topic: =={ Challenge }== Decompress String  (Read 13173 times)
ElpanovEvgeniy
  • Moscow (Russia)
Re: =={ Challenge }== Decompress String
« Reply #15 on: August 29, 2014, 08:06:00 AM »
recursion:
  1. (defun f (s a / b)
  2.   (cond ((= s "") a)
  3.         ((= (atoi s) 0) (f (substr s 2) (strcat a (substr s 1 1))))
  4.         ((f (substr s 2) (progn (setq b "") (repeat (atoi (substr s 1 1)) (setq b (strcat a b))))))
  5.   )
  6. )
test:
(f "ab2c3" "")
"ababcababcababc"
(f "ab4c3d2" "")
"ababababcababababcababababcdababababcababababcababababcd"
(f "a23" "")
"aaaaaa"
Jeff H
« Reply #16 on: August 29, 2014, 08:13:49 AM »
Just starting to mess with AutoLisp so total noob here
  1. (defun Decompress (string)
  2.  (recursiveDecompress "" string)
  3. )
  4.
  5. (defun recursiveDecompress (string1 string2 / str3)
  6.  (setq str3 "")
  7.  (cond
  8.    ((equal "" string2) string1)
  9.    ((repeat (atoi string2) (setq str3 (strcat str3 string1)))
  10.       (recursiveDecompress str3 (substr string2 2)))
  11.    (T (recursiveDecompress (strcat string1 (substr string2 1 1)) (substr string2 2)))
  12.   )
  13. )
  14.
  15.
Jeff H
« Reply #17 on: August 29, 2014, 08:27:06 AM »
That's what I get for being noob  this might be correct depending on if this is correct
_$ (Decompress "a23")
"aaaaaa"
Does (Decompress "a23") =  "aaaaaa" or "aaa"?
  1. (defun recursiveDecompress (string1 string2 / str3)
  2.  (setq str3 "")
  3.  (cond
  4.    ((equal "" string2) string1)
  5.    ((repeat (atoi (substr string2 1 1)) (setq str3 (strcat str3 string1)))
  6.       (recursiveDecompress str3 (substr string2 2)))
  7.    (T (recursiveDecompress (strcat string1 (substr string2 1 1)) (substr string2 2)))
  8.   )
  9. )
  10.
  11.
« Reply #18 on: August 29, 2014, 08:31:49 AM »
"aaaaaa"
Yes.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #19 on: August 29, 2014, 08:32:23 AM »
hi Jeff H!
We have written the same code  :coolsmiley:
« Reply #20 on: August 29, 2014, 08:38:36 AM »
Ahhh, I see you've changed the 'specs' to clarify ...
That's how it works in real life. The specs have a way of evolving to accommodate the unforeseen. It helps to have several perspectives.  8)
« Reply #21 on: August 29, 2014, 08:41:40 AM »
My argument has always been that we need to learn how to ask questions as much as we need to learn to solve problems.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #22 on: August 29, 2014, 08:52:42 AM »
good words!  :-)
« Reply #23 on: August 29, 2014, 09:26:37 AM »
Thank you Sir!
irneb
« Reply #24 on: August 29, 2014, 09:40:36 AM »
+1 I agree with you on this, unfortunately I didn't foresee the possibilities. In my mind some of them didn't matter - seeing as they didn't apply to the results (only to the implementation).
My thought on changing the original was that instead of someone having to read all the following posts - the queries asked later were to be incorporated. At least those where I felt I failed to mention in the OP. Sorry guys.
Jeff H
« Reply #25 on: August 29, 2014, 09:42:25 AM »
hi Jeff H!
Either I got lucky or you screwed up.
 :-D
Jeff H
« Reply #26 on: August 29, 2014, 09:47:33 AM »
hi Jeff H!
Hi Elpanov,
I do not have much experience with Lisp but can most problems be solved in Lisp  with
   (DEFUN <RECURSIVE-FUNCTION> (<PARAM1> ... <PARAMN>)
       (COND (<TERMINATING-CONDITION1> <RESULT1>)
             (<TERMINATING-CONDITIONN> <RESULTN>)
             (<RECURSIVE-CONDITION1> <RECURSIVE-CALL1>)
             (<RECURSIVE-CONDITIONM> <RECURSIVE-CALLM>)))
irneb
« Reply #27 on: August 29, 2014, 09:52:44 AM »
Yes "most" ... though unlike some other Lisps (e.g. Scheme) AutoLisp doesn't have tail-call-elimination, thus recursion would cause stack overflows if the call stack becomes too deep. So generally be careful when you're processing something like a list longer than around 10k to 20k.
Actually if you program in something like Scheme / Clojure you're encouraged to use recursion instead of iterative loops. But that's not always the case, e.g. Common Lisp tends to make use of iterative looping instead.
roy_043
  • BricsCAD 18
« Reply #28 on: August 29, 2014, 10:05:59 AM »
Two more from me.
Roy_Decompress_3 is similar to Roy_Decompress_2 but probably faster because it relies less on string operations.
Roy_Decompress_4 is my version with recursion.
  1. (defun Roy_Decompress_3 (str / out tmp)
  2.   (foreach int (vl-string->list str)
  3.     (cond
  4.       ((<= 50 int 57) ; 2-9
  5.         (setq tmp out)
  6.         (repeat (- int 49)
  7.           (setq out (append tmp out))
  8.         )
  9.       )
  10.       ((= int 48) ; 0
  11.         (setq out nil)
  12.       )
  13.       ((/= int 49) ; 1
  14.         (setq out (append out (list int)))
  15.       )
  16.     )
  17.   )
  18.   (vl-list->string out)
  19. )
  1. (defun Roy_Decompress_4 (str / N_Decode)
  2.   (defun N_Decode (lst / out tmp)
  3.     (cond
  4.       ((not lst)
  5.         nil
  6.       )
  7.       ((= (car lst) 48) ; 0
  8.         nil
  9.       )
  10.       ((<= 49 (car lst) 57) ; 1-9
  11.         (setq tmp (N_Decode (cdr lst)))
  12.         (repeat (- (car lst) 48)
  13.           (setq out (append tmp out))
  14.         )
  15.       )
  16.       (T
  17.         (cons (car lst) (N_Decode (cdr lst)))
  18.       )
  19.     )
  20.   )
  21.   (vl-list->string (reverse (N_Decode (reverse (vl-string->list str)))))
  22. )
« Reply #29 on: August 29, 2014, 10:06:06 AM »
Without looking at anything already posted:
  1. (defun decompress ( s / f )
  2.     (defun f ( s x r )
  3.         (cond
  4.             (   (= "" s) x)
  5.             (   (wcmatch s "#*")
  6.                 (if (< 0 (atoi s))
  7.                     (f (strcat (itoa (1- (atoi s))) (substr s 2)) x (strcat r x))
  8.                     (f (substr s 2) r "")
  9.                 )
  10.             )
  11.             (   (f (substr s 2) (strcat x (substr s 1 1)) r))
  12.         )
  13.     )
  14.     (f s "" "")
  15. )
