Command: TTSelect objects: Specify opposite corner: 3 foundSelect objects:*Invalid selection*Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle; error: Function cancelled
Works in 2015.
Can you load it from the VLIDE ( as lisp code) with Debug->BreakOnError toggled on.Then select Last Break Source when you get an error
Which line is it breaking on ??See this to help discover the line ..http://www.theswamp.org/index.php?topic=47623.msg526380#msg526380QuoteCan you load it from the VLIDE ( as lisp code) with Debug->BreakOnError toggled on.Then select Last Break Source when you get an error
; === Top statistic:; Global variables: (AREA DIS I J K L LL OBJ1 OBJ2 OS PS PTC PTE PTM PTS RADIUS SSDATA SSN SSTYPE SS_L SS_SP SS_TMP1 SS_TMP2); Function definition (with number of arguments): ((DRAW . 1) (C:TT . 0)); Check done.
