Author Topic: Why don't return 0.579176?  (Read 1927 times)
2e4lite
« on: August 23, 2014, 04:07:35 AM »
As following:
(vlax-curve-getParamAtPoint obj '(269.17 53.9658 0.0))return: nil
_$ p0
_$ (vlax-curve-getParamAtPoint obj p0)
0.579176
Stefan
Re: Why don't return 0.579176?
« Reply #1 on: August 23, 2014, 04:36:44 AM »
The numbers in the list are truncated.
Try
(equal p0 '(269.17 53.9658 0.0))
To see the differences, try
(mapcar '(lambda (x) (rtos x 2 16)) p0)
(mapcar '(lambda (x) (rtos x 2 16)) '(269.17 53.9658 0.0))
« Reply #2 on: August 23, 2014, 11:28:47 AM »
Try this:
  1. (vlax-curve-getParamAtPoint obj  (vlax-curve-getClosestPointTo obj '(269.17 53.9658 0.0)))
2e4lite
« Reply #3 on: August 23, 2014, 09:15:29 PM »
Very thanks for your helpful reply!
