When you say " I've tried creating an ObjectOverrule for Groups but only the Open event fires when a Group is copied", are you saying that in your overridden Open() and Close() methods, only code in the Open() method runs and code in Close() is not triggered? Or, you did not override Close() method?
I wrote a simple ObjectOverrule class and did a quick test:
namespace GroupObjectOverrule
public class MyGroupObjectOverrule : ObjectOverrule
private static MyGroupObjectOverrule _instance = null;
public static MyGroupObjectOverrule Instance
get
if (_instance == null) _instance = new MyGroupObjectOverrule();
return _instance;
public void StartOverrule()
AddOverrule(RXClass.GetClass(typeof(Group)), this, false);
this.SetNoFilter();
Overruling = true;
public void StopOverrule()
RemoveOverrule(RXClass.GetClass(typeof(Group)), this);
Overruling = false;
public override void Open(DBObject dbObject, OpenMode mode)
base.Open(dbObject, mode);
//ed.WriteMessage("\nDBObject is opened: {0}", dbObject.GetType().Name);
public override void Close(DBObject dbObject)
//ed.WriteMessage("\nDBObject is to be closed: {0}", dbObject.GetType().Name);
if (dbObject.IsNewObject)
Group g = dbObject as Group;
if (g != null)
ed.WriteMessage(
"\nGroup name: {0}; group description: {1}\n",
g.Name, g.Description);
base.Close(dbObject);
and
using CadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(GroupObjectOverrule.MyCadCommands))]
public class MyCadCommands
private static bool _overruled = false;
[CommandMethod("GroupOR")]
public static void ToggleGroupOverrule()
Document dwg = CadApp.DocumentManager.MdiActiveDocument;
if (dwg == null) return;
Editor ed = dwg.Editor;
try
if (!_overruled)
MyGroupObjectOverrule.Instance.StartOverrule();
_overruled = true;
ed.WriteMessage("\nMyGroupOverrule enabled.");
else
MyGroupObjectOverrule.Instance.StopOverrule();
_overruled = false;
ed.WriteMessage("\nMyGroupOverrule disabled.");
catch (System.Exception ex)
ed.WriteMessage("\nError: {0}\n{1}", ex.Message, ex.StackTrace);
finally
Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
In testing, I start AutoCAD, NETLOAD the code, run the command GROUPOR.
Then I create a few entities, run command GROUP to put the entities in a anonymous group. Then I select the group, and copy the group to different location. I can clearly see the command line list the new anonymous group name (*A2) printed by my code in Close() method.
By the way, the original anonymous group is named *A1, if I use "ClassicGroup" command to examine the groups in drawing.
So, yes, you can use ObjectOverrule to catch the newly created group. However, you may need to find out a way to determine if the newly created group is your targeting group you want to assign description to it.
