Author Topic: acad2015 possible bug switching tabs  (Read 3533 times)
ZNETQ
« on: August 06, 2014, 07:50:04 AM »
bonjour, I'm trying to migrate from acad2012 to acad2015
Can someone with AutoCAD 2015 evaluates if the following is a reproducible bug ?
Switching between drawings via Ctrl+Tab is not working in this situation:
. Open AutoCAD 2015, Open a new drawing, Drawing1, Open a new drawing, Drawing2
. In Drawing2, draw a rectangle and select it
. type "_copybase" "0,0,0"
. immediately after, press Ctrl+Tab to switch to Drawing1
--> nothing happens unless you move the mouse and re-Ctrl+Tab
huiz
  • Certified Prof C3D
Re: acad2015 possible bug switching tabs
« Reply #1 on: August 06, 2014, 08:33:05 AM »
That is because the commandline is active. If you click once on the commandline and you see the blinking cursor, it also is not possible to switch drawings. Until the drawing area is active again, then you can switch.
« Reply #2 on: August 06, 2014, 08:49:24 AM »
Tile the drawings
select the object
Rt-Click -hold down
continue holding down
Drag into destination drawing
use option of your choice
Paste Here
Paste to original coordinates
Paste as Block
ZNETQ
« Reply #3 on: August 06, 2014, 09:37:27 AM »
Thanks!
The commandline was indeed stealing the focus. It can be active, the *problem* occurs when DYNMODE = 0, which was my setting
I set DYNMODE higher and everything works as expected
Problem solved!
