Author Topic: Trivial problem with function "setq" "read" "if"  (Read 1879 times)
Lupo76
« on: June 18, 2014, 06:12:28 AM »
Hello to all,
I need to use the IF function with a constant variable.
I'm sorry but it's hard to explain.
Perhaps the following code helps
(setq trial (read (strcat "trial_" "1")))
Now if I write in AutoCAD: "!trial_1" (without quotes) is output 1.
So far so ok
If you then write
(if (= (read "trial_1") "1")
    (alert "true")
    (alert "false")
is issued "false". Why?
Where did I go wrong?
David Bethel
Re: Trivial problem with function "setq" "read" "if"
« Reply #1 on: June 18, 2014, 06:16:52 AM »
Try :
(if (= (eval (read "trial_1")) "1")
-David
R12 Dos - A2K
Lupo76
« Reply #2 on: June 18, 2014, 07:04:27 AM »
perfect! thank you!
irneb
« Reply #3 on: June 18, 2014, 07:19:05 AM »
Just to be clear for those who might not understand what's going on, read doesn't return the variable - it returns the quoted version of the symbol name. So the following 3 lines return the same thing:
  1. (read "my-var-name")
  2. (quote my-var-name)
  3. 'my-var-name
Note read only does this for the 1st form found in the string. A form can be a string (if escape quoted), a number (int/float), a symbol or a list:
  1. (read "1 2 3") ; Returns 1
  2. (read "var1 var2 var3") ; Returns VAR1
  3. (read "(var1 var2 var3)") ; Returns (VAR1 VAR2 VAR3)
In all cases the returned value is unevaluated.
Eval then takes the quoted symbol (or for that matter any Lisp syntax) and evaluates it to its result as if run.
So you get the following happening:
  1. (eval ; Will evaluate the following argument, then returns the result
  2.   (read ; Convert a string into a Lisp form to evaluate and returns this form
  3.     "trail_1" ; There's just this symbol as text, anything after it will be ignored
  4.   ) ; returns TRIAL_1, not the value inside it, but the quoted symbol
  5. ) ; returns the value inside the TRIAL_1 symbol
MeasureUp
« Reply #4 on: July 03, 2014, 08:41:35 PM »
Thanks to irneb.
Your helps to guys (like me) who wish to understand the autolisp are much appreciated.
BTW I have learned from your threads for years.
irneb
« Reply #5 on: July 04, 2014, 12:45:51 AM »
Thanks to irneb.
You're very welcome!  :-D
mailmaverick
« Reply #6 on: July 05, 2014, 11:23:56 AM »
Excellent explanation irneb !!!!
Great work !!!
Much appreciated !!!!!!
