Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Missing Attributes when using VS 2013
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Missing Attributes when using VS 2013 (Read 1285 times)
MexicanCustard
Swamp Rat
on:
May 08, 2014, 10:52:31 AM »
Just switched to Visual Studio 2013. I'm finding that if I start AutoCAD MEP from the debugger then all block attributes and any text I've drawn with a DrawableOverrule are not showing up. Attributes and Overrules show up fine if I start MEP normally and NETLOAD my plug in. Anyone have any experience with this?
Logged
Gasty
Newt
Re: Missing Attributes when using VS 2013
Reply #1 on:
May 08, 2014, 11:16:33 PM »
Let me guess: Autocad 2014, win 7/8 64 bits...it seems that you touched a *fiber*, see this link:
http://through-the-interface.typepad.com/through_the_interface/2013/11/debugging-autocad-using-visual-studio-2013.html
Gaston Nunez
Logged
MexicanCustard
Swamp Rat
Reply #2 on:
May 09, 2014, 09:09:17 AM »
Thanks Gasty. This sucks, main reason to upgrade was for 64 bit Edit and Continue. Looks like that's not possible in AutoCAD. Does anyone know if the issue exist in using AutoCAD 2015? We're in the process of upgrading now.
Logged
Gasty
Newt
Reply #3 on:
May 09, 2014, 11:10:35 AM »
Autocad 2015 works perfectly (until now) in 64 bits + VS 2013, edit and continue works nicely, and there is no fibers in 2015, so you don't need to set nextfiberworld to 0 with all the collateral damage that imply doing so.
Gaston Nunez
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
