So, after a bout of frustration, I erased and recreated the entire section group. I then noticed that I could select everything, but as soon as I added my centerline alignment that I would use to draw in my ROW lines, for the cross sections that don't have a row in the sample, you cannot select them. If I remove the row alignment, the ones that you couldn't select before, you are able to select.
