Author Topic: "NENTSEL" from paperspace - anyone know a better way?  (Read 3748 times)
PKENEWELL
« on: April 04, 2014, 02:56:53 PM »
Hi All,
I just created this function to be able to return entity data from a modelspace viewport while in paperspace. Does anyone have a better method than switching back and forth from Paperspace to Modelspace viewport to get the entity under the cursor? Any coding improvements would also be welcome.
  1. ;|==============================================================================
  2.   Function Name: (pjk-PS-Nentsel)
  3.
  4.   Written By: Phil Kenewell
  5.         Date: 4/4/2014
  6.     Revision: 0.1 -   4/4/2014; First Release.
  7.               0.2  - 4/14/2014; Added a way to active the viewport intended by the user.
  8.               Thanks to Kruuger on theSwamp.org
  9.
  10.   Arguments: pr = string; A user prompt for the command line
  11.              kw = Keyword Codes for (initget)
  12.
  13.   Usage: (pjk-PS-Nentsel <Prompt>)
  14.
  15.   Returns:
  16.            if an object is present in modelspace or paperspace under the cursor,
  17.            it returns a list in the format returned by (nentsel).
  18.            i.e. (<Entity name: 7ffffb088e0> (3.74275 3.40795 0.0)) for standard entity
  19.            or (<Entity name: 7ffffb14090> (3.68518 4.04064 0.0) ((1.0 0.0 0.0 3.65343)
  20.               (0.0 1.0 0.0 4.16154) (0.0 0.0 1.0 0.0) (0.0 0.0 0.0 1.0)) (<Entity name: 7ffffb140a0>))
  21.            if the entity is nested
  22.
  23.   Description:
  24.      This function is similar to (nentsel), except that:
  25.         1) it tests for missed picks by the pointing device and loops to
  26.            allow the user to re-select,
  27.         2) Honors Keywords if "kw" argument is supplied, and
  28.         3) it finds objects under the cursor from a modelspace viewport if
  29.            no object exists to select in paperspace.
  30.
  31.      NOTE: This function causes a slight flash when switching to a modelspace viewport
  32.            and back if in paperspace. It would be nice to find a better way to do this!
  33. ================================================================================|;
  34. (defun pjk-PS-Nentsel (pr kw / ad cnt ent flg p ss)
  35.    (if kw (initget kw))
  36.    (if (> (getvar "CVPORT") 1) ; if in Modelspace
  37.       (while (and (not (setq ent (nentsel pr)))(= (getvar "errno") 7))
  38.          (princ "\nNo Object Selected. Try Again...\n")
  39.          (if kw (initget kw))
  40.       )
  41.       (while (not ent)
  42.          (if (and (not (setq ent (nentsel pr)))(= (getvar "errno") 7))
  43.             (progn
  44.                (setq p  (cadr (grread nil 1)) cnt 0
  45.                      ss (ssget "_X" (list (cons 0 "VIEWPORT")(cons 410 (getvar "CTAB"))))
  46.                      ad (vla-get-activedocument (vlax-get-acad-object))
  47.                )
  48.                (vla-put-mspace ad :vlax-true)
  49.                (while (and (not ent) (< cnt (sslength ss)))
  50.                    (vla-put-activepviewport ad (vlax-ename->vla-object (ssname ss cnt)))
  51.                    (if (setq p1 (osnap (trans p 3 2) "nea"))(setq ent (nentselp p1) flg T))
  52.                    (setq cnt (1+ cnt))
  53.                )
  54.                (vla-put-mspace ad :vlax-false)
  55.             )
  56.             (if (not ent)(setq ent T))
  57.          )
  58.          (if (not ent)
  59.             (progn (if kw (initget kw))(princ "\nNo Object Selected. Try Again...\n"))
  60.             ;; translate the point picked back into paperspace.
  61.             (if (and flg (= (type ent) 'LIST))
  62.                 (if (> (length ent) 2)
  63.                     (setq ent
  64.                        (list
  65.                           (car ent)
  66.                           (trans (cadr ent) 2 3)
  67.                           (cdr (member (cadr ent) ent))
  68.                        )
  69.                     )
  70.                     (setq ent (list (car ent) (trans (cadr ent) 2 3)))
  71.                 )
  72.             )
  73.          )
  74.       )
  75.    )
  76.    (if (= ent T) nil ent)
  77. );; End Function (pjk-PS-Nentsel)
  78.
Thanks!
EDIT: I added an argument and code to the function to honor Keywords.
EDIT 2: I realized that if the data was a block as returned by (nentsel), I was trunicating the rest of the data - corrected.
EDIT 3: added a flag to prevent translating the picked point if the selected object was already in paperspace.
EDIT 4: Version 0.2 - Updated code to iterate through the all viewports in the current layour to find the picked object.
« Last Edit: April 14, 2014, 04:12:37 PM by PKENEWELL »
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
PKENEWELL
Re: "NENTSEL" from paperspace - anyone know a better way?
« Reply #1 on: April 07, 2014, 02:38:43 PM »
No ideas from anyone on this?
« Last Edit: April 10, 2014, 05:00:39 PM by PKENEWELL »
PKENEWELL
« Reply #2 on: April 10, 2014, 05:03:33 PM »
Silence? Well - either:
1) No one has any suggestions at all for my code,
2) I broke some rule on this forum and I'm getting shunned, Or
3) I accidently engaged that cloaking device MP was talking about?
 :-D
danallen
« Reply #3 on: April 10, 2014, 06:10:35 PM »
I see you, but have no ideas...
Dan
kruuger
« Reply #4 on: April 11, 2014, 05:09:53 AM »
 ;D
is your code know on above which viewport your make a "click" ?
there was great code to translate coord. form paper to model by gile:
http://www.theswamp.org/index.php?topic=29231.msg347755#msg347755
also need viewport selection for point translation.
question is, can we make point selection in model but being in paper space ?
k
PKENEWELL
« Reply #5 on: April 11, 2014, 09:49:55 AM »
@danallen: Thanks for the reply. Even if you couldn't give an answer, it's nice to have an acknowledgement of a post.  :-)
k
Hi Kruuger - Thanks much for your reply! This function made the assumption that switching to a modelspace viewport, it will activate the viewport under the cursor. I was incorrect. If there is another viewport - it will activate the last created. In this case the function does not work properly. Thanks also for the link from gile. I will study this to try and figure out a better way to do what i'm attempting. The problem I have now is how to determine what viewport the user is trying to select objects in.
Maybe some of the experts here will have some ideas?
kruuger
« Reply #6 on: April 11, 2014, 04:01:16 PM »
If there is another viewport - it will activate the last created. In this case the function does not work properly... The problem I have now is how to determine what viewport the user is trying to select objects in.
exactly.
you can catch VIEWPORT with this:
[code]
(setg pt (getpoint "\nSelect point: ")
      ds (getvar "VIEWSIZE")
      p1 (polar Pt (* 0.5 pi) ds)
      ss (ssget "_F" (list Pt p1)'((0 . "VIEWPORT")))
than check if point is inside - see image. all three points grab the VIEWPORT but only green is correct.
maybe it will be useful.
kruuger
PKENEWELL
« Reply #7 on: April 11, 2014, 06:07:53 PM »
kruuger
Thanks Kruuger! I will look into this and get back with updated code as soon as I can.
PKENEWELL
« Reply #8 on: April 14, 2014, 04:33:30 PM »
1st post updated with my latest version of the function.
kruuger
Kruuger,
Thanks. Your post got me thinking about it. Your suggested code has a few problems:
1) If the viewport is not completely visible in the current view - the ssget "F" option does not work.
2) if the viewports layer is turned off, the above ssget code also does not work.
Fortunately - your reply got me thinking about another bit of code you posted: http://www.theswamp.org/index.php?topic=38197.0
In that post you were selecting *all* the viewports and iterating through them. I tried this method - iterating through all viewports and trying to find a viewport that has the object under the cursor - and it seems to work well so far. It seems that (nentselp) will not find anything that is not visible within a viewport if the coordinates are not within the boundary.
For now - this function does what I need it to do. Although I will still look further into this for problems, and to find out a way to get the entity without activating a viewport (Like AutoCAD's dimensions can do). I dont know if this is possible without using nenselp, which only works in the active space.
Thanks again! Phil.
danallen
« Reply #9 on: April 14, 2014, 05:57:32 PM »
if visually overlapping objects can be found in multiple viewports, will your routine give an option to the user?
PKENEWELL
« Reply #10 on: April 15, 2014, 09:50:25 AM »
Hi Danallen,
No I don't believe this will allow for overlapping objects, and I'm not sure if it would be possible to do so, or at least I would not know how to do it. I was hoping the experts on this forum would point me towards a better method.
