Author Topic: Coordinates of current Zoom Window  (Read 9885 times)
snownut2
  • Bricscad 22 Ultimate
Re: Coordinates of current Zoom Window
« Reply #15 on: April 01, 2014, 07:47:47 AM »
....old people, hehe! To make this more relevant you all aren't so old, my grandfather was programming military systems in fortran in the 50's and 60's.
I had a yr of FORTRAN in college, thank god for IBM
There's one old college text book wouldn't be worth 10 cents today. (why do I still have it.)
Bhull1985
« Reply #16 on: April 01, 2014, 08:24:47 AM »
Memories? :)
hmspe
« Reply #17 on: April 01, 2014, 08:47:38 AM »
Memories.  Yes.  Hollerith cards.  IBM 370. Fortran.  T.A. who wrote 'goto' with slashed through the o's.  Business students in the study room in the dorm who struggled with basic math, and engineering students who would do their homework (in seconds) to get them to stop griping about how hard their homework was....
"Science is the belief in the ignorance of experts." - Richard Feynman
ymg
« Reply #18 on: April 01, 2014, 01:22:19 PM »
From Express Tools:
(ACET-GEOM-VIEW-POINTS)
Will return a list Lower Left and Upper Right as 3d points.
((3737.61 598.711 0.0) (10595.1 3058.81 0.0))
Timing for 1 000 000 repetitions:
ACET                      Elapsed: 1.528 sec.
ve                          Elapsed: 9.859 sec.
LM:ViewportExtents  Elapsed: 9.813 sec.
vpcords                  Elapsed: 9.891 sec.
« Last Edit: April 01, 2014, 01:42:10 PM by ymg »
« Reply #19 on: April 01, 2014, 01:40:58 PM »
express tools, meh
ymg
« Reply #20 on: April 01, 2014, 01:46:42 PM »
express tools, meh
 :lmao: Have to agree with you, it is a mixed bag.
ymg
hmspe
« Reply #21 on: April 01, 2014, 02:42:51 PM »
But it is very simple code:
(defun acet-geom-view-points ( / a b c d x )
 (setq b (getvar "viewsize")
       c (car  (getvar "screensize"))
       d (cadr (getvar "screensize"))
       a (* b (/ c d))
       x (trans (getvar "viewctr") 1 2)
       c (list (- (car  x) (/ a 2.0))
               (- (cadr x) (/ b 2.0))
               0.0
       d (list (+ (car  x) (/ a 2.0))
               (+ (cadr x) (/ b 2.0))
               0.0
       c (trans c 2 1)
       d (trans d 2 1)
 (list c d)
ymg
« Reply #22 on: April 01, 2014, 03:04:35 PM »
hmspe,
no need to define it if you have Express Tool installed.
Believe it is part of aceutil.fas
All you need is:
(setq vext (ACET-GEOM-VIEW-POINTS))
ymg
hmspe
« Reply #23 on: April 01, 2014, 05:11:33 PM »
ymg,
I understand, but there are those who either do not have express tools or will not use express tools because they cannot be locally maintained or because they can't be sure everyone has them installed.
danallen
« Reply #24 on: April 01, 2014, 05:42:24 PM »
or on Bricscad!
« Reply #25 on: April 01, 2014, 06:15:30 PM »
lee,
I like the:
(apply '/ (getvar 'screensize))
Neat!
ymg
Thanks ymg  :-)
ymg
« Reply #26 on: April 02, 2014, 08:59:30 AM »
@danallen,
Express Tools for Bricscad can be downloaded here: http://www.bricsys.com/common/applications/application.jsp?app=589
@hmspe,
I certainly do not advocate the use of acet for everything.  I was merely showing the possibilities.
As for the installed base, most everybody has them.
What is more of a problem is that documetation for them is kind of sparse,
plus some of the functions are less than ideal.  So your mileage may (will) vary.
ymg
« Reply #27 on: April 02, 2014, 09:03:16 AM »
What is more of a problem is that documentation for them is kind of sparse,
ymg
That covers the issue very well, I think.
