Author Topic: "Numbering" attributes on layouts: 1 of 5, 2 of 5, 3 of 5...  (Read 2244 times)
kruuger
« on: March 10, 2014, 06:49:37 AM »
hello
small tool for "numbering" block attributes. maybe someone find in usefull.
find attached sample dwg for tests.
(defun _Main (BlockName Tag1 Separator Tag2 Custom / lay tot ss)
  (setq lay (cdr (cd:DWG_LayoutsList))
        tot (itoa (length lay))
  (cd:SYS_UndoBegin)
  (foreach % lay
      (setq ss
        (ssget "_X"
          (append
           '((0 . "INSERT"))
            (list
              (cons 2 (strcase BlockName))
              (cons 410 (car %))
      (if Tag2
          (cd:BLK_SetAttValueVLA (ssname ss 0) Tag1
            (if Custom Custom (itoa (cadr %)))
          (cd:BLK_SetAttValueVLA (ssname ss 0) Tag2 tot)
          (if Custom
            (strcat Custom Separator tot)
            (strcat (itoa (cadr %)) Separator tot)
  (cd:SYS_UndoEnd)
  (princ (strcat "\nUpdated " tot " title borders "))
(_Main "BL1" "DRAWING_NUMBER" " of " nil nil)
(_Main "BL1" "DRAWING_NUMBER" " of " nil "%<\\AcVar ctab>%")
(_Main "BL1" "DRAWING_NUMBER" " - "  nil nil)
(_Main "BL1" "DRAWING_NUMBER" "/"    nil nil)
(_Main "BL2" "DRAWING_NUMBER" nil "TOTAL" nil)
(_Main "BL2" "DRAWING_NUMBER" nil "TOTAL" "%<\\AcVar ctab>%")
any improvements/suggestions/other situation to consider are welcome
kruuger
Bhull1985
Re: "Numbering" attributes on layouts: 1 of 5, 2 of 5, 3 of 5...
« Reply #1 on: March 10, 2014, 09:11:00 AM »
Wow nice pack Kruuger, thanks a lot.
I've taken the time this morning to clean it up for English-speaking persons, attached to this post is a re-formatted English version only of the same function library you've posted.
Easier to read for me, means easier to use....maybe others will find this to be the case as well
« Last Edit: March 10, 2014, 09:29:16 AM by Bhull1985 »
kruuger
« Reply #2 on: March 10, 2014, 10:48:06 AM »
thanks. it is a community work.
http://forum.cad.pl/cadpl-pack-v1-lsp-t78158.html?hilit=CADPACK%20DYSKUSJA
k.
