Author Topic: Disposing in Project.ProjectModel object model  (Read 1556 times)
cannorth
« on: February 21, 2014, 04:31:47 PM »
Hello,
   Which objects of the Project.ProjectModel object model requiring disposing in a project mostly?  I'm tracking down memory corruption.
Thanks,
cannorth
kaefer
Re: Disposing in Project.ProjectModel object model
« Reply #1 on: February 21, 2014, 07:34:05 PM »
Those on which System.IDisposable is implemented. But then I've never heard of Project.ProjectModel.
« Reply #2 on: February 21, 2014, 07:47:14 PM »
cannorth
« Reply #3 on: February 24, 2014, 10:10:53 AM »
  Yes, the object model I refered to is: Autodesk.Gis.Map.Project.ProjectModel
