Author Topic: Field in Title Block with some math?  (Read 1710 times)
« on: February 09, 2014, 04:12:10 PM »
I want a Field in the Title Block (Mtext) to get the Tab name which is 1 through 12 and add to it a Custom Property "TB-StartPage" which is "11"
Result will be 12 13 14 .... in each title block.
Can the be done?
I haven't used Fields much & still in ACAD 2006.
kruuger
Re: Field in Title Block with some math?
« Reply #1 on: February 09, 2014, 05:00:56 PM »
Can the be done?
hi cab
i'm not sure if understand correctly but you need apply this string to mtext:
"%<\AcVar ctab>% & %<\AcVar CustomDP.TB-StartPage>%"k.
« Reply #2 on: February 09, 2014, 05:32:17 PM »
Not quite there.
Ctab = 1
TB-Startpage = 11
Text should read 12
"%<\AcVar ctab>% + %<\AcVar CustomDP.TB-StartPage>%"
If I could do it in LISP
"(itoa(+ (atoi %<\AcVar ctab>%) (atoi %<\AcVar CustomDP.TB-StartPage>%) )"
« Reply #3 on: February 09, 2014, 06:14:12 PM »
Untested, but try:
%<\AcExpr %<\AcVar ctab>% + %<\AcVar CustomDP.TB-StartPage>% >%
« Reply #4 on: February 09, 2014, 06:37:11 PM »
WOW  it was under my nose all the time.  :oops:
Thanks Lee.
« Reply #5 on: February 09, 2014, 06:52:19 PM »
No worries!  :-)
