Author Topic: Add a space in front of every text on a spreadsheet that is to be link into Auto  (Read 1890 times)
diego65
  • Learning LISP is a cool thing
Hello,
What we are trying to achieve is to be able to create a macro or a LISP that will allow us to add a blank space infront of every text inside every cell on a spreadsheet by selecting a specific Column.
This spreadsheet will have all drawing numbers listed and Bill of Materails, then linked onto Autocad via Link Manager.
It is posible to manipulate the code below to achieve this?
Sub Macro()
' Addspace
' Keyboard Shortcut: Ctrl+s
    ActiveCell.Columns("A:A").EntireColumn.Select
    'cell.Value = cell.Value & "  "
ActiveColumn.Value = ActiveColumn.Value & "  "
Thank you...
Bhull1985
Wrong forum, think this should go into the .net one
MickD
vba actually :)
but, try: (not tested! but will get you started)
Code - vb.net: [Select]
  1. Sub AddSpaceToTextInCell()
  2. Dim r As Range, cell As Range
  3. Dim colNumber As Long, colLetter As String
  4.
  5. ' get the letter of the active cell's column:
  6. colNumber = ActiveCell.Column
  7.
  8. 'get the ascii number and turn it to a char, needs
  9. 'more work for more tha A-Z columns :)
  10. colLetter = Chr(colNumber + 64)
  11.
  12. ' create a range to loop through:
  13. Set r = Range(colLetter & "1:" & colLetter & "1000")
  14.
  15. ' loop through it and add some space to the front of every cell that contains text
  16. For Each cell In r
  17.     If cell.Text <> "" Then
  18.         cell.Text = " " & cell.Text
  19.     End If
  20. Next
  21.
  22. End Sub
- John Carmack
- J.R.R. Tolkien
