Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Create a Hatch
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Create a Hatch (Read 1583 times)
Fabricio28
Swamp Rat
Create a Hatch
on:
January 17, 2014, 06:57:39 AM »
Hi guys,
How Can I make a hatch with that dimension 0.625 x 1.25 meters??
Thank in advance.
Logged
Rob...
King Gator
Take a little time to stop and smell the roses.
Re: Create a Hatch
Reply #1 on:
January 17, 2014, 07:05:32 AM »
Draw a rectangle and hatch it?
Logged
CAD Tech
Global Moderator
Seagull
Re: Create a Hatch
Reply #2 on:
January 17, 2014, 07:40:11 AM »
http://www.theswamp.org/index.php?topic=4814.msg191815#msg191815
Logged
Fabricio28
Swamp Rat
Re: Create a Hatch
Reply #3 on:
January 17, 2014, 07:58:50 AM »
@ RobDraw
Thank you for suggestion. I'll try this out.
@ CAB
I don't know how to use that code to create my own hatch ( rectangle 0.625 x 1.25).
Maybe a lisp will be wonderful.
regards
Logged
Global Moderator
Seagull
Re: Create a Hatch
Reply #4 on:
January 17, 2014, 09:20:19 PM »
Start with this:
Code - Auto/Visual Lisp:
[Select]
defun
entmakex
hatch
L
;; By ElpanovEvgeniy
;; 03.04.2007 10:03:51:
entmakex
apply
append
list
list
0
"HATCH"
100
"AcDbEntity"
410
"Model"
100
"AcDbHatch"
10
0.0
0.0
0.0
210
0.0
0.0
1.0
2
"SOLID"
70
1
71
0
cons
91
length
l
;_ list
apply
append
mapcar
lambda
a
apply
append
list
list
92
7
72
0
73
1
cons
93
length
a
mapcar
lambda
b
cons
10
b
a
97
0
;_ list
;_ apply
;_ lambda
l
;_ mapcar
75
0
76
1
47
1
98
2
10
0
0
0.0
10
0
0
0.0
451
0
460
0.0
461
0.0
452
1
462
1.0
453
2
463
0.0
463
1.0
470
"LINEAR"
;_ list
;_ apply
;_ entmakex
defun
c:test
pt x y
setq
pt '
100
150
; lower left corner
setq
x
car
pt
y
cadr
pt
setq
h
entmakex
hatch
list
list
pt
list
x
y
1.25
list
x
0.625
y
1.25
list
x
0.625
y
;_ entmakex-hatch
;_ setq
Logged
Fabricio28
Swamp Rat
Re: Create a Hatch
Reply #5 on:
January 20, 2014, 09:15:29 AM »
Thank you CAB,
I was trying to create a hatch with dimension (0,64x1,20).
Select the perimeter that I want to hatch and create rectangle in it.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
Create a Hatch
