Author Topic: Run a command as if from the command line  (Read 2258 times)
hmspe
« on: January 03, 2014, 08:49:29 PM »
I'm working on a routine that needs to run the MIRROR command in the middle of a lisp function.  Rather than simulating all the calls and data gathering then using (command "mirror" .... ) where I pass in the the previously gathered data I'd like to find a way to have my routine call the mirror function and let it run as a command line function (prompting for input, etc.), then returning control to my lisp function.  Is there a way to do this?
"Science is the belief in the ignorance of experts." - Richard Feynman
Re: Run a command as if from the command line
« Reply #1 on: January 03, 2014, 09:16:06 PM »
Try something like :
  1. (defun c:doit ()
  2.   (apply 'vl-cmdf (list "_.MIRROR"))
  3.   (while (> (getvar "cmdactive") 0) (vl-cmdf pause))
  4.
  5.   (setq success (getstring t "Say What"))
  6.   (alert (strcat "We got to here\n" success))
  7.   (princ)
  8. )
hmspe
« Reply #2 on: January 03, 2014, 10:42:50 PM »
Thanks.
« Reply #3 on: January 03, 2014, 11:40:43 PM »
de nada
« Reply #4 on: January 04, 2014, 12:04:02 PM »
A minor point, but:
  1. (apply 'vl-cmdf (list "_.MIRROR"))
Could just be:
  1. (vl-cmdf "_.mirror")
David Bethel
« Reply #5 on: January 04, 2014, 02:01:54 PM »
You may also want set CMDECHO to 1.  Otherwise you could be flying blind   :wink:
R12 Dos - A2K
« Reply #6 on: January 04, 2014, 05:34:25 PM »
A minor point, but:
Could just be:
I'm in the habit of doing it my way because I often pass arguments in the list.
Sort of comes second nature to set up for the extended functionality.
yes :)
« Reply #7 on: January 04, 2014, 06:48:01 PM »
A minor point, but:
Could just be:
I'm not sure I follow - surely arguments could still be passed using the single vl-cmdf statement?
  1. (vl-cmdf "_.mirror" arg1 arg2 ... argN)
