Author Topic: Mtext {\\Format Codes } ?  (Read 3806 times)
snownut2
  • Bricscad 22 Ultimate
« on: December 29, 2013, 11:04:32 AM »
There is a list of Mtext codes similar to;
(setq sampletxt "{\\C2;\\LEnter Text Here}")
That causes the Text Line to have the desired format.
The above code will make the line "Underlined Yellow text" for example.
Unfortunately I can not locate a list of these codes (I should have saved them the last time I found them...)
Any ideas or links to this would be appreciated.
Bruce
Re: Mtext {\\Format Codes } ?
« Reply #1 on: December 29, 2013, 11:09:18 AM »
The documentation offers this, but I'm not convinced that its a complete reference.  :|
« Reply #2 on: December 29, 2013, 11:09:40 AM »
Haven't had coffee yet, but would this be useful?
http://msdn.microsoft.com/en-us/library/office/aa140302(v=office.10).aspx
snownut2
« Reply #3 on: December 29, 2013, 11:22:50 AM »
Thanks Lee, just what I was looking for.
Bruce
snownut2
« Reply #4 on: December 29, 2013, 02:15:39 PM »
I've been trying to Left justify some text lines and Center others to no avail....
This does not appear to be do-able.
Bruce
« Reply #5 on: December 29, 2013, 02:38:17 PM »
  1. (defun c:test ( / p )
  2.     (if (setq p (getpoint "\nPoint for text: "))
  3.         (entmake
  4.             (list
  5.                '(000 . "MTEXT")
  6.                '(100 . "AcDbEntity")
  7.                '(100 . "AcDbMText")
  8.                 (cons 010 (trans p 1 0))
  9.                '(001 . "\\pxql;Left\\P\\pqc;Centered\\P\\pqr;Right")
  10.                '(041 . 12.0)
  11.                '(040 .  1.0)
  12.             )
  13.         )
  14.     )
  15.     (princ)
  16. )
Jeff H
« Reply #6 on: December 29, 2013, 03:14:08 PM »
One thing you can do is create the formatting manually then select the MText and look at the Contents property displayed in Property Palette.
From Developer Documentation:
MText.Contents Property
Accesses the character contents of the MText object. Formatting data used for word wrap calculations is removed before the string is copied.
MText.Text Property
Accesses the MText contents with formatting removed
