Author Topic: Temporary Command Line Message  (Read 2060 times)
Odoshi
« on: December 26, 2013, 11:40:30 AM »
I'd like to put a counter at the command line but not have it show all items in the command line history, like the following:
Adjusting item 1
Adjusting item 2
But I would like it to just "spin" and then when it is finished, maybe only display the last message.
Is this possible in .NET?
Thanks!
Anton3
  • Mosquito
Re: Temporary Command Line Message
« Reply #1 on: January 13, 2014, 04:16:34 PM »
Is this what you want?
 [CommandMethod("LongOP")]
        public void LongOperation()
            Document doc=Application.DocumentManager.MdiActiveDocument;
            Database db=doc.Database;
            Editor ed=doc.Editor;
            int maxItems=1000;
            int iToShow=150;
            int i=0;
            while( i< maxItems)
                if ((i % iToShow)==0)
                    ed.WriteMessage("\nAdjusting item {0}",i+1);
                i++;
            ed.WriteMessage("\nAll {0} items adjusted",i);
elliottpd
« Reply #2 on: January 15, 2014, 02:15:26 PM »
If you write a message to the command line without the leading new line character (\n or vblf), then overwrite with the next message, the numbers appear to spin, while the rest of the message is static:
myEditor.WriteMessage("Updating block " & Cnt.ToString & " of " & myIDs.Count & vbCr)
IDabble
« Reply #3 on: January 15, 2014, 08:31:03 PM »
Yes, leave out the new line character "\n".
For your second and consecutive Editor.WriteMessage calls, you can lead them with one or more Unicode backspace characters "\u0008".
For example, one backspace character in C# prior to string "hello":
Editor.WriteMessage("\u0008hello");
hth
Odoshi
« Reply #4 on: January 16, 2014, 01:36:18 PM »
Thanks for the replies!
I'll give those a try in a bit. I've got code to do it in LISP with the old -. /, |, \ ,-...remember those days? ;)
Regards,
Mike
MexicanCustard
« Reply #5 on: January 16, 2014, 02:38:17 PM »
Regards,
Mike
LISP = Lost In Stupid Parentheses
