Author Topic: I need a beta tester now  (Read 33433 times)
daron
« Reply #45 on: December 19, 2003, 11:58:21 AM »
Killed was loose terminology. That would be determined by what you would call alive? I'm sure a eulogy would be funny.
My guess is that 0111 didn't.
« Reply #46 on: December 19, 2003, 12:01:50 PM »
Stig, No i didnt. (I didnt do decimals either.) I was just  planning on using it for regular ascii, 8 bit, numbers.
SMadsen
« Reply #47 on: December 19, 2003, 01:04:31 PM »
No decimals? Darn! I was planning on doing a bitwise EQUAL function for double-precision floating point numbers.
« Reply #48 on: December 19, 2003, 01:44:45 PM »
I can add that in there if you would like?  ...Ill PM ya.
Dent Cermak
« Reply #49 on: December 19, 2003, 02:34:16 PM »
Man, is this getting esoteric or what !?
« Reply #50 on: December 19, 2003, 02:53:45 PM »
Hey dent, don't use big words that we don't understand fully..
Like IS and OR
(hey it worked for Clinton)
t-bear
« Reply #51 on: December 19, 2003, 04:46:31 PM »
Clinton huh?  Did ya see where Dent's from?  Hmmmmmmm......
As for bein' esso-whatch-a-ma-call-it, It's just a bunch-a 1s & 0s to me......kinda like that bic thingie.
daron
« Reply #52 on: December 19, 2003, 04:47:33 PM »
Told ya 0111.
« Reply #53 on: December 19, 2003, 04:54:35 PM »
"01000100 01100001 01110010 01101111 01101110 00101100 00100000 01001001 01101101 00100000 01110011 01110100 01101001 01101100 01101100 00100000 01100111 01101111 01101001 01101110 01100111 00100000 01110100 01101111 00100000 01100101 01101110 01100011 01110010 01111001 01110000 01110100 00100000 01110100 01101000 01100101 00100000 01100100 01100001 01110100 01100001 00100000 01100010 01100101 01100110 01101111 01110010 01100101 00100000 01101001 00100000 01100011 01101111 01101110 01110110 01100101 01110010 01110100 00100000 01110100 01101111 00100000 01100010 01101001 01101110 01100001 01110010 01111001"
daron
« Reply #54 on: December 19, 2003, 05:04:48 PM »
01001001 00100000 01110111 01101111 01110101 01101100 01100100 01101110 00100111 01110100 00100000 01100101 01111000 01110000 01100101 01100011 01110100 00100000 01100001 01101110 01111001 01110100 01101000 01101001 01101110 01100111 00100000 01101100 01100101 01110011 01110011 00101110  :D
t-bear
« Reply #55 on: December 19, 2003, 05:15:04 PM »
When I try to run it in "reverse" this is what I get:
I convert strings to binary representations.
Tell me the string you whish converted to a binary representation: 01001001
(Darons answer to 7)
I have successfully converted "01001001 00100000 01110111 01101111 01110101
01110100 01101000 01101001 01101110 01100111 00100000 01101100 0110" to:
00110000 00110001 00110000 00110000 00110001 00110000 00110000 00110001
00100000 00110000 00110000 00110001 00110000 00110000 00110000 00110000
00110000 00100000 00110000 00110001 00110001 00110001 00110000 00110001
00110001 00110001 00100000 00110000 00110001 00110001 00110000 00110001
00110001 00110001 00110001 00100000 00110000 00110001 00110001 00110001
00110000 00110001 00110000 00110001 00100000 00110000 00110001 00110001
00110000 00110001 00110001 00110000 00110000 00100000 00110000 00110001
00110001 00110000 00110000 00110001 00110000 00110000 00100000 00110000
00110001 00110001 00110000 00110001 00110001 00110001 00110000 00100000
00110000 00110000 00110001 00110000 00110000 00110001 00110001 00110001
00100000 00110000 00110001 00110001 00110001 00110000 00110001 00110000
00110000 00100000 00110000 00110000 00110001 00110000 00110000 00110000
00110000 00110000 00100000 00110000 00110001 00110001 00110000 00110000
00110001 00110000 00110001 00100000 00110000 00110001 00110001 00110001
00110001 00110000 00110000 00110000 00100000 00110000 00110001 00110001
00110001 00110000 00110000 00110000 00110000 00100000 00110000 00110001
00110001 00110000 00110000 00110001 00110000 00110001 00100000 00110000
00110001 00110001 00110000 00110000 00110000 00110001 00110001 00100000
00110000 00110001 00110001 00110001 00110000 00110001 00110000 00110000
00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110000
00110000 00110001 00100000 00110000 00110001 00110001 00110000 00110001
00110001 00110001 00110000 00100000 00110000 00110001 00110001 00110001
00110001 00110000 00110000 00110001 00100000 00110000 00110001 00110001
00110001 00110000 00110001 00110000 00110000 00100000 00110000 00110001
00110001 00110000 00110001 00110000 00110000 00110000 00100000 00110000
00110001 00110001 00110000 00110001 00110000 00110000 00110001 00100000
00110000 00110001 00110001 00110000 00110001 00110001 00110001 00110000
00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110001
00110001 00100000 00110000 00110000 00110001 00110000 00110000 00110000
00110000 00110000 00100000 00110000 00110001 00110001 00110000 00110001
00110001 00110000 00110000 00100000 00110000 00110001 00110001 00110000
I work! Please tell Se7en for me.
nil
I just copy/ pasted it into an open dwg and ran "Binny"....
So what am I doing wrong?  I MUST be doin' SUMPIN wrong, right?
If I did it right it wouldn't be wrong! Or maybe I'M RIGHT!  It's the WORLD THAT'S.....Ah well...... :cry:
« Reply #56 on: December 19, 2003, 05:33:20 PM »
Oh Bear, Daron figured out the function name to convert a bin string back to ascii. ....Something i didnt want to happen. :lol: (I wanted to keep that part quite untill i got it cleaned up a bit.)
we are just goofing off, no biggy.
daron
« Reply #57 on: December 19, 2003, 06:17:16 PM »
Figured it out? I wrote one.
« Reply #58 on: December 19, 2003, 07:10:45 PM »
...even better!
Dent Cermak
« Reply #59 on: December 19, 2003, 07:16:10 PM »
What ?
