Author Topic: help with DCL - Embedding an image (logo) in a dialog  (Read 3483 times)
pedroantonio
« on: December 02, 2013, 12:01:07 PM »
I am trying to add a logo in a DCL . I miss somthing   :| and i need  alitle help..
Here  is my code
dcl code
//about.dcl
//Program to help dimension points of a section
nest2:dialog{
label="about";
: row {
        alignment = centered;
        : image_button {
            color = black ;
            fixed_height = true ;
            fixed_width = true ;
            height = 14 ;
            key = "im" ;
            width = 18 ;
:boxed_column{
:paragraph{
:text_part{
label="Example";
texth=14;
:spacer{
 width=1;
:text_part{
label="Hello ";
:spacer{
 width=1;
:text_part{
label="This is an example";
:spacer{
 width=1;
:text_part{
label="test";
:spacer{
 width=1;
:text_part{
label="test ";
:spacer{
 width=1;
:text_part{
label="bla-bla-bla .....";
:spacer{
 width=1;
:text_part{
label="end";
:spacer{
 width=1;
ok_only;
lisp code
(defun c:about () ;define function
  (setq dcl_id1 (load_dialog "about.dcl")) ;load the DCL file
  (slide_image 0 0 max_x max_y "imge2")
  (end_image)
  (if (not (new_dialog "nest2" dcl_id1)) ;load the nested dialogue box
    (exit)
  ) ;if not loaded exit
  (action_tile
    "accept"
    "(done_dialog) (setq userclick1 T)" ;close dialog, set flag
  ) ;action_tile
  (start_dialog) ;start the nested dialog box
  (unload_dialog dcl_id1) ;unload the nested dialogue box
Vandyck
Re: help with DCL - Embedding an image (logo) in a dialog
« Reply #1 on: December 02, 2013, 12:19:31 PM »
reading AutoLISP code on the fly seems to me that is missing
(start_image "imge2")
to be inserted before
pedroantonio
« Reply #2 on: December 02, 2013, 12:47:25 PM »
dcl
//about2.dcl
nest2:dialog{
label="about";
: row {
        : image_button {
            color = black ;
            height = 14 ;
            key = "im" ;
            width = 18 ;
:boxed_column{
:paragraph{
:text_part{
label="Example";
texth=14;
:spacer{
 width=1;
:text_part{
label="Hello ";
:spacer{
 width=1;
:text_part{
:spacer{
 width=1;
:text_part{
label="test";
:spacer{
 width=1;
:text_part{
label="test ";
:spacer{
 width=1;
:text_part{
:spacer{
 width=1;
:text_part{
label="end";
:spacer{
 width=1;
ok_only;
lisp
(defun c:about2 () ;define function
  (setq dcl_id1 (load_dialog "about2.dcl")) ;load the DCL file
  (end_image)
    (exit)
  (action_tile
    "accept"
  ) ;action_tile
gives me this error
"c:\user\admin\desktop\about\about2.dcl" at-end-of-file : premature end of file
"c:\user\admin\desktop\about\about2.dcl" at-end-of-file : syntax error  Symbol: "ok_only".
Command: (LOAD "C:/Users/Prodromos/Desktop/DiaTabs/about2.lsp") C:ABOUT2
Command: ABOUT2
; error: bad argument type: fixnump: nil
« Last Edit: December 02, 2013, 12:52:24 PM by pedroantonio »
efernal
« Reply #3 on: December 02, 2013, 03:24:14 PM »
in your dcl file, image_button's key is "im"
in your lsp code, you are using "imge2"
max_x and max_y are undefined (see dimx_tile and dimy_tile functions...)
e.fernal
efernal
« Reply #4 on: December 02, 2013, 03:26:39 PM »
also, you are trying to use an image_button before  (new_dialog ...
e.fernal
« Reply #5 on: December 02, 2013, 03:31:15 PM »
I haven't tried to decipher your code logic, but the braces don't match in your DCL file
.. making sure your code is structurally correct would be a good place to start.
pedroantonio
« Reply #6 on: December 02, 2013, 04:36:20 PM »
i still have errors
  1. //about2.dcl
  2. //Program to help dimension points of a section
  3. : image_button {
  4. color = black ;
  5. fixed_height = true ;
  6. fixed_width = true ;
  7. height = 14 ;
  8. key = "imge2" ;
  9. width = 18 ;
  10.         }
  11. nest2:dialog{
  12. label="about";
  13.
  14. :boxed_column{
  15. :paragraph{
  16. :text_part{
  17. label="Example";
  18.             alignment = centered;
  19. texth=14;
  20.          }
  21.
  22. :spacer{
  23.  width=1;
  24.         }
  25. :text_part{
  26. label="Hello ";
  27.             alignment = centered;
  28.           }
  29. :spacer{
  30.  width=1;
  31.         }
  32. :text_part{
  33. label="This is an example";
  34.             alignment = centered;
  35.           }
  36. :spacer{
  37.  width=1;
  38.         }
  39. :text_part{
  40. label="test";
  41.             alignment = centered;
  42.           }
  43. :spacer{
  44.  width=1;
  45.         }
  46. :text_part{
  47. label="test ";
  48.             alignment = centered;
  49.           }
  50. :spacer{
  51.  width=1;
  52.         }
  53. :text_part{
  54. label="bla-bla-bla .....";
  55.             alignment = centered;
  56.           }
  57. :spacer{
  58.  width=1;
  59.         }
  60. :text_part{
  61. label="end";
  62.             alignment = centered;
  63.           }
  64. :spacer{
  65.  width=1;
  66.         }
  67.           }
  68.           }
  69. ok_only;
  70.             }
« Last Edit: December 02, 2013, 07:06:17 PM by pedroantonio »
efernal
« Reply #7 on: December 02, 2013, 05:22:09 PM »
//about2.dcl
my_image : image_button { color = black ; fixed_height = true ;
           fixed_width = true ; height = 14 ;
           key = "imge2" ; width = 18 ;
nest2: dialog { label="about";
:row { alignment=centered; fixed_width=true; fixed_height=true;
:column{fixed_width=true;fixed_height=true;
my_image;
:boxed_column{
:paragraph {
:text_part { label = "Example"; alignment = centered;  /* texth = 14; */ }
:spacer { width = 1; }
:text_part { label = "Hello "; alignment = centered; }
:text_part { label = "This is an example"; alignment = centered; }
:text_part { label = "test"; alignment = centered; }
:text_part { label = "test "; alignment = centered; }
:text_part { label = "bla-bla-bla ....."; alignment = centered; }
:text_part{ label = "end"; alignment = centered; }
          } // paragraph
          } // boxed_column
          } // row
ok_only;
e.fernal
pedroantonio
« Reply #8 on: December 02, 2013, 06:54:05 PM »
efernal thunk you for the code but, i run the lisp but gives me this error
in your screen shot the image is black.Why?
dcl
  1. //about2.dcl
  3. my_image : image_button { color = black ; fixed_height = true ;
  4.            fixed_width = true ; height = 14 ;
  5.            key = "imge2" ; width = 18 ;
  6.            }
  7.
  8. nest2: dialog { label="about";
  9. :row { alignment=centered; fixed_width=true; fixed_height=true;
  10. :column{fixed_width=true;fixed_height=true;
  11. my_image;
  12. }
  13. :boxed_column{
  14. :paragraph {
  15. :text_part { label = "Example"; alignment = centered;  /* texth = 14; */ }
  16. :spacer { width = 1; }
  17. :text_part { label = "Hello "; alignment = centered; }
  18. :spacer { width = 1; }
  19. :text_part { label = "This is an example"; alignment = centered; }
  20. :spacer { width = 1; }
  21. :text_part { label = "test"; alignment = centered; }
  22. :spacer { width = 1; }
  23. :text_part { label = "test "; alignment = centered; }
  24. :spacer { width = 1; }
  25. :text_part { label = "bla-bla-bla ....."; alignment = centered; }
  26. :spacer { width = 1; }
  27. :text_part{ label = "end"; alignment = centered; }
  28. :spacer { width = 1; }
  29.           } // paragraph
  30.           } // boxed_column
  31.           } // row
  32. ok_only;
  33. }
  34.
lisp
  1. (defun c:about2 ()                      ;define function
  2.
  3.   (setq dcl_id1 (load_dialog "about2.dcl")) ;load the DCL file
  4.   (start_image "imge2")
  5.   (slide_image 0 0 max_x max_y "imge2")
  6.   (if (not (new_dialog "nest2" dcl_id1)) ;load the nested dialogue box
  7.     (exit)
  8.   )                                     ;if not loaded exit
  9.     "accept"
  10.     "(done_dialog) (setq userclick1 T)" ;close dialog, set flag
  11.   )                                     ;action_tile
  12.   (start_dialog)                        ;start the nested dialog box
  13.   (unload_dialog dcl_id1)               ;unload the nested dialogue box
  14. )
  15.
« Last Edit: December 03, 2013, 02:55:25 AM by pedroantonio »
efernal
« Reply #9 on: December 03, 2013, 06:32:02 AM »
  1. ;|
  2. (DEFUN c:about2 ()                      ;define function
  3.   (SETQ dcl_id1 (LOAD_DIALOG "about2.dcl")) ;load the DCL file
  4.   (START_IMAGE "imge2")
  5.   (SLIDE_IMAGE 0 0 max_x max_y "imge2")
  6.   (END_IMAGE)
  7.   (IF (NOT (NEW_DIALOG "nest2" dcl_id1)) ;load the nested dialogue box
  8.     (EXIT)
  9.   )                                     ;if not loaded exit
  10.   (ACTION_TILE
  11.     "accept"
  12.     "(done_dialog) (setq userclick1 T)" ;close dialog, set flag
  13.   )                                     ;action_tile
  14.   (START_DIALOG)                        ;start the nested dialog box
  15.   (UNLOAD_DIALOG dcl_id1)               ;unload the nested dialogue box
  16. )
  17. |;
  18. (DEFUN c:about2 (/ dh dx dy)
  19.   (IF (> (SETQ dh (LOAD_DIALOG "about2.dcl")) 0)
  20.     ;; here you can provide the dcl path, like "C:\\Dcls\\About2.dcl"
  21.     (IF (NEW_DIALOG "nest2" dh)
  22.       (PROGN (SETQ dx (DIMX_TILE "imge2")
  23.                    dy (DIMY_TILE "imge2")
  24.              )
  25.              (START_IMAGE "imge2")
  26.              (SLIDE_IMAGE 0 0 dx dy "imge2")
  27.              ;; here you can provide the image path, like "C:\\Slds\\Imge2.sld"
  28.              (END_IMAGE)
  29.              (ACTION_TILE "accept" "(DONE_DIALOG)")
  30.              (START_DIALOG)
  31.              (UNLOAD_DIALOG dh)
  32.       )
  33.       nil
  34.     )
  35.     (ALERT "Error:\n\n\n\tCould not load dcl file...")
  36.   )
  37.   (PRINC)
  38. )
  39.
  40.
e.fernal
pedroantonio
« Reply #10 on: December 03, 2013, 10:57:36 AM »
Thank you efernal  :-) ,but i want a little change. look the photo
« Last Edit: December 03, 2013, 12:33:35 PM by pedroantonio »
pedroantonio
« Reply #11 on: December 03, 2013, 11:21:56 AM »
dcl
  1. //about2.dcl
  6.            }
  7.
  11. my_image;
  12. }
  13. :boxed_column{
  14. :paragraph {
  29.           } // paragraph
  31.           } // row
  32. ok_only;
  33. }
  34.
lisp
  1. ;|
  6.   (END_IMAGE)
  8.     (EXIT)
  10.   (ACTION_TILE
  11.     "accept"
  13.   )                                     ;action_tile
  16. )
  17. |;
  24.              )
  28.              (END_IMAGE)
  30.              (START_DIALOG)
  32.       )
  33.       nil
  34.     )
  36.   )
  37.   (PRINC)
  38. )
  39.
« Last Edit: December 03, 2013, 12:33:23 PM by pedroantonio »
snownut2
  • Bricscad 22 Ultimate
« Reply #12 on: December 03, 2013, 05:29:47 PM »
pedroantonio,
All the code in the DCL is there, just take a look at it.  For example the DCL starts out with a ROW (the ROW is not terminated until the end), then there are 2-columns within the ROW the 1st column contains the IMAGE and the 2nd boxed_column contains the paragraph.  You should be able to figure this out if you study what is already there.
It seems you want to eliminate the ROW and just have 2-columns one above the other instead of beside each other.
You can load the DCL in the Visual Lisp Editor in ACAD (vlide) and make the adjustments then preview very quickly.
Bruce
efernal
« Reply #13 on: December 03, 2013, 06:23:54 PM »
  1. nest2: dialog { label="about";
  2. :spacer{height=0.5;}
  3. :column{fixed_width=true;fixed_height=true;
  4. :image_button { color = black ; fixed_height = true ;
  5. fixed_width = true ; width = 44; aspect_ratio = 0.35 ; key = "imge2" ; }
  6. :boxed_column{
  7. :text{ label = "Example"; alignment = centered; }
  8. :text{ label = "Hello "; alignment = centered; }
  9. :text{ label = "This is an example"; alignment = centered; }
  10. :text{ label = "test"; alignment = centered; }
  11. :text{ label = "test "; alignment = centered; }
  12. :text{ label = "bla-bla-bla ....."; alignment = centered; }
  13. :text{ label = "end"; alignment = centered; }
  14.          } // boxed_column
  15.          } // column
  16. ok_only;
  17. }
  18.
e.fernal
pedroantonio
« Reply #14 on: December 03, 2013, 06:29:56 PM »
Thank you all for the help  :-)
