Author Topic: need some ideas for a scrolling save message... (confusing i know)  (Read 1513 times)
andrew_nao
(defun c:nsave (/ activedoc docfullname backuppath archivename dwgbakk)
(if (= (getvar "dwgtitled") 0)
 (PROGN
   (initdia)
   (command ".saveas")
  (setq activedoc (vla-get-activedocument (vlax-get-acad-object)))
(vla-save activedoc)
  (if (and (not (= 0 (strlen (setq docfullname (vla-get-fullname activedoc)))))
           (setq backuppath "C:\\ACADBACK\\")
           (setq archivename (strcat backuppath
                                     (vl-filename-base (vla-get-name activedoc))
                                     ".dwg"
    (setq dwgbakk (vl-file-copy docfullname archivename))
    (alert "Ooooops. Unable to get Filename.")
  (if (= dwgbakk nil)
(vl-file-delete archivename)
  (prompt (strcat "\n\nFile Saved..." archivename))
  (prompt (strcat "\n\nFile Saved..." docfullname))
here is my code for a custom save.
when "save" is clicked, it shows "file saved..."
if you click save over and over it, saves. but there is no way of it showing it saved again (it doesnt appear to scroll) unless you press f2 for the history window.
im looking for a way to have it display some type of scroll to show it saved again.
i hope this makes sense. and ideas are appreciated
Re: need some ideas for a scrolling save message... (confusing i know)
« Reply #1 on: November 06, 2013, 03:30:27 PM »
You could use grtext to display: (grtext -2 (vla-get-fullname activedoc))
roy_043
  • BricsCAD 18
« Reply #2 on: November 06, 2013, 04:36:47 PM »
Just a question:
After using
(vla-save activedoc)Can
(vla-get-fullname activedoc)Ever return an empty string?
