Author Topic: Relative Paths  (Read 2921 times)
ChrisCarlson
Relative Paths
« on: November 04, 2013, 08:27:35 AM »
We recently brought on a new, outsourced IT department which wants to start archiving project files. Is there a way to default xrefs (inserted pdf's/tiffs) as relative paths to the .dwg file? Currently ACAD 2014 inserts xrefs with an absolute path, upon archiving this path will be broken and we need to re-attach or relocate the xrefs.
BlackBox
Re: Relative Paths
« Reply #1 on: November 04, 2013, 08:42:04 AM »
Here's Jimmy's SETPATHTYPE function.
To batch manipulate stored XREF paths in drawings, use Reference Manager.
HTH
dgorsman
Re: Relative Paths
« Reply #2 on: November 04, 2013, 10:01:43 AM »
Just remember, if the path changes drives it *cannot* be relative.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
Matt__W
  • I like my water diluted.
Re: Relative Paths
« Reply #3 on: November 04, 2013, 10:11:51 AM »
Why not?  As long as the folder structure stays the same, the xref file locations are relative to the source file, regardless of drive.
Autodesk Expert Elite
Rob...
Re: Relative Paths
« Reply #4 on: November 04, 2013, 11:10:26 AM »
We tried using relative pathing for archiving and it didn't work but I can't remember why. We kept the folder structure the same but there was something about the upper levels that screwed it up.
CAD Tech
dgorsman
Re: Relative Paths
« Reply #5 on: November 04, 2013, 12:15:27 PM »
If your content is on X:\Some\path\here\... then you cannot provide a relative path to Y:\Another\path\there\...
For example, we have engineers stamps as XREFs in a write protected drive which is separate from the projects drive.  Those XREFs cannot be changed to relative paths because they are on a separate drive, even though the other drawings are all on the same drive.
try {GreatPower;}
      {MasterBasics;}
Matt__W
Re: Relative Paths
« Reply #6 on: November 04, 2013, 01:23:02 PM »
Gotcha!  I was under the impression that all of your files were on the same drive.  So, yeah...  that makes sense.
ChrisCarlson
Re: Relative Paths
« Reply #7 on: November 04, 2013, 02:00:35 PM »
We have (2) drives
G:\ = AutoCAD support files, plotters, lisps, templates, etc. This is constant so no worries here.
I:\ = Project drive, this is the problem drive. Every 100 new projects numbers, the oldest 100 are archived to a separate long term storage array. Occasionally we need to access these projects for revisions, reprints, etc.
Once the project folder is moved the referenced TIFF link is broken. If the attached file is a .dwg, AutoCAD allows relative paths but Tiffs/PDF's appear to be absolute paths only.
danallen
Re: Relative Paths
« Reply #8 on: November 04, 2013, 03:14:30 PM »
Have you looked into projectname variable and paths? The solution might be to add automation to check if xref paths are unresolved, change projectname which allows that drawing to look into other listed folders for xrefs, then use your automation to reload unresolved xrefs.
ChrisCarlson
Re: Relative Paths
« Reply #9 on: November 04, 2013, 04:11:38 PM »
No I have not.
However if I insert the TIFF/PDF via "xref" and "Attach image" I can choose relative path and it works as intended even if the project folder in it's entirety moves around.
Inserting images this way is tedious and :ugly:, I'll have to dig into the system variables and see if there is an option I can change for default attach method.
Re: Relative Paths
« Reply #10 on: November 04, 2013, 07:21:23 PM »
Could you use ARCHIVE or ETRANSMITT to new location?
ChrisCarlson
Re: Relative Paths
« Reply #11 on: November 05, 2013, 03:53:04 PM »
We could if that's how our IT department archived, presently they drag and drop (or automated version) via windows explorer.
