Author Topic: Run exe program through lisp  (Read 1668 times)
Coder
« on: September 27, 2013, 06:45:19 AM »
Hello guys .  :-)
Is it possible to run a exe file through lisp ?
Many thanks.
snownut2
  • Bricscad 22 Ultimate
Re: Run exe program through lisp
« Reply #1 on: September 27, 2013, 06:49:07 AM »
Yes it is possible, you will be returned to the lisp once the exe is complete.  (will even run and allow a dialog box to remain in place in CAD).
TimSpangler
  • CAD Naked!!
« Reply #2 on: September 27, 2013, 07:12:12 AM »
Look at the "startapp" function
ACA 2015 - Windows 7 Pro
Coder
« Reply #3 on: September 27, 2013, 08:28:02 AM »
Thank you all guys for your time .
Just for clarification , I am talking about VBA.exe file and not Windows Application .
Or is it the same ?
NOT SURE
« Reply #4 on: September 27, 2013, 10:50:46 AM »
You can call a VBA function from lisp, if that's what you're getting at.
(vl-vbaload "Your VBA function")
(vl-vbarun "Your VBA function")
Coder
« Reply #5 on: September 27, 2013, 11:24:51 AM »
That looks very promising , I will try it on Sunday and will let you know .
Many thanks :-)
