Author Topic: Place prefix in front Layer name  (Read 11294 times)
Fabricio28
« on: September 25, 2013, 02:25:04 PM »
Hi all,
I'm looking for a routine will place a Prefix (-) in front of a layers names by selected objects.
e.g
Layer Name: STREET
Layer Name: - STREET
Anybody Can help me please?
Kind Regards
Krushert
  • FREE BEER Tomorrow!!
Re: Place prefix in front Layer name
« Reply #1 on: September 25, 2013, 02:45:10 PM »
I have no idea where I got this.  I had to go to the Lisp Trunk in attic to get it because I really do not use it much more.
I think I got it from Cadalyst.  :|  It was probably authored by a Swamp Denizen anyway.  :lmao:
;;; LAYER-NAME-CHANGE.LISP
;;; CHANGES LAYER NAME BY ADDING A PREFIX OR/AND SUFFIX
(defun C:ChgLayName (/ acadDocument theLayers layName pre)
    (vl-cmdf ".undo" "begin")
  (setq p_fix (getstring "\nEnter Layer Prefix : ")
s_fix (getstring "\nEnter Layer Suffix : ")
  (setq acadDocument (vla-get-activedocument (vlax-get-acad-object)))
  (setq theLayers (vla-get-layers acadDocument))
  (vlax-map-collection theLayers 'layer-mod)
  (vl-cmdf ".undo" "end")
) ;defun
(defun layer-mod (theLayer)
  (setq layName (vlax-get-property theLayer 'Name))
  (if (not (member layName '("0" "Defpoints" "XREF")))
    (vla-put-Name thelayer (strcat p_fix layName s_fix))
  ) ;if
) ;defun
FWIW:  I was just recently shown that Rename command can utilize wild cards to add or strip prefixes or suffixes from layer names.
Thanks TedG
« Reply #2 on: September 25, 2013, 02:59:15 PM »
You could also use something like this:
(defun c:foo (/ e el l pre)
  (if (and (setq e (car (entsel))) (setq pre (getstring t "\nEnter prefix: ")))
    (progn (setq l (cdr (assoc 8 (entget e))))
      (setq el (entget (tblobjname "layer" l)))
      (if (wcmatch (strcase l) (strcat (strcase pre) "*"))
        (princ "\nLayer already has that prefix...")
        (entmod (subst (cons 2 (strcat pre l)) (assoc 2 el) el))
« Last Edit: September 25, 2013, 03:15:23 PM by ronjonp »
Fabricio28
« Reply #3 on: September 25, 2013, 03:04:27 PM »
Thank you for the quick replay guys,
@Krushert
Thank for sharing the code, but isn't exacatly I was looking for.
Regards
It is perfect, ronjonp!
Is it possible add multiple section in the code, please?
Best Regards
« Reply #4 on: September 25, 2013, 03:19:41 PM »
Here you go:
(defun c:foo (/ _ss->list e el l pre ss)
  (defun _ss->list (ss / n out)
    (repeat (setq n (sslength ss)) (setq out (cons (ssname ss (setq n (1- n))) out)))
  (if (and (setq pre (getstring t "\nEnter prefix: ")) (setq ss (ssget)))
    (foreach e (_ss->list ss)
Fabricio28
« Reply #5 on: September 25, 2013, 03:36:44 PM »
You're awesome!!!
Thank you very much.
Fabricio
« Reply #6 on: September 25, 2013, 08:45:40 PM »
Glad to help. :)
MSTG007
« Reply #7 on: October 07, 2013, 07:55:54 AM »
I thought I did something wierd here. I used the FOO command; and the entity i selected was renamed to the new layer, but so did all the other objects on that layer. Am I doing something wrong?
I have layer 1 and select an object. Then would assign a prefix line demo_; and finally look like in the layer name as demo_1?
Civil3D 2020
« Reply #8 on: October 07, 2013, 09:11:27 AM »
Sorry about that .. the routine above just renames the layer. If you want the object to be moved to the new layer use the code below.
    (progn (foreach e (_ss->list ss)
       (progn (princ "\nObject already has that layer prefix..."))
       (progn (if (not (tblobjname "layer" (strcat pre l)))
(entmakex (subst (cons 2 (strcat pre l)) (assoc 2 el) el))
      (entmod (subst (cons 8 (strcat pre l)) (assoc 8 (entget e)) (entget e)))
MSTG007
« Reply #9 on: October 07, 2013, 09:23:02 AM »
whoot! Again you dah man!
Civil3D 2020
« Reply #10 on: October 07, 2013, 09:35:31 AM »
engtechy
« Reply #11 on: August 18, 2016, 04:44:48 PM »
I realize this is an old post. I know enough about lisp to be dangerous.... how would I modify that last routine to add a suffix instead of the prefix?
Thanks.
rkmcswain
« Reply #12 on: August 18, 2016, 04:55:59 PM »
Try this:
  (if (and (setq pre (getstring t "\nEnter suffix: ")) (setq ss (ssget)))
      (if (wcmatch (strcase l) (strcat "*" (strcase pre)))
(princ "\nLayer already has that suffix...")
(entmod (subst (cons 2 (strcat l pre)) (assoc 2 el) el))
Fabricio28
« Reply #13 on: November 08, 2016, 01:43:08 PM »
Here you go:
Hi guys,
That code is amazing, I've been using a lot ...
I'm using that code to add - as a prefix of my layers.
I'd like to make a little change at the code.
Remove - of all selected layers.
Thanks in advance
ribarm
  • Marko Ribar, architect
« Reply #14 on: November 08, 2016, 01:59:35 PM »
Hi guys,
Thanks in advance
If I understood correctly and if the code passed your tests... (untested)
(defun c:foo ( / _ss->list f-MR e el l ll ss )
  (defun _ss->list ( ss / n out )
  (defun f-MR ( d s / d1 dl k ss c pl z l )
    (while (and (setq d1 (substr d 1 1)) (/= d1 ""))
      (setq d (substr d 2))
      (setq dl (cons d1 dl))
    (foreach d1 dl
      (setq k -1 ss s)
      (while (and (setq c (substr ss 1 1)) (/= c ""))
        (setq ss (substr ss 2))
        (setq k (1+ k))
        (if (= c d1)
          (setq pl (cons k pl))
    (if pl
        (setq pl (vl-sort pl '<))
        (foreach p pl
          (if (null z)
            (setq z 1)
          (setq l (cons (substr s z (1+ (- p z))) l))
          (setq z (+ p 2))
        (setq l (cons (substr s z) l))
        (vl-remove "" (reverse l))
      s
  (if (setq ss (ssget))
      (if (vl-string-search "-" l)
          (setq ll (f-MR "-" l))
          (setq ll (apply 'strcat ll))
          (entmod (subst (cons 2 ll) (assoc 2 el) el))
Regards...
M.R. on Youtube
