Some time ago I have updated that reference:
Source: http://www.theswamp.org/index.php?topic=3313.msg40725#msg40725
Source: http://www.theswamp.org/index.php?topic=33507
2 improvements and several additions by RKG.
Additional variables based on: http://www.hyperpics.com/system_variables/
Art Cooney (artc@autodesk.com)
There's a description of the codes in the ObjectARX documentation (I've included
it below). I don't think the DXF documentation explains the overrides.
Here's the description from the ObjectARX docs:
Dimension style overrides can be applied to any of the AcDbEntity types that
reference an AcDbDimStyleTableRecord. These are:
AcDbAlignedDimension
AcDbRotatedDimension
AcDbDiametricDimension
AcDbRadialDimension
AcDb2LineAngularDimension
AcDb3PointAngularDimension
AcDbOrdinateDimension
AcDbLeader
AcDbFcf
Dimension overrides applied to an object of any of these classes are stored as
xdata under the "ACAD" appId in a special subsection. The subsection starts with
a group code 1000 (AcDb::kDxfXdAsciiString) with the string "DSTYLE", followed
by all the dimension override data bracketed inside a pair of group code 1002's
(AcDb::kDxfXdControlString) (the first being a "{" and the other a "}").
Dimension variables in general are called dimvars, and this data is commonly
called "per-entity dimvar overrides" or just dimvar overrides.
Within the group code 1002 brackets is a chain of dimvar group-code/data-value
resbuf pairs, one pair for each dimvar being overridden.
The first resbuf in each pair is the DXF group code for the dimvar, as found in
the Table below. Since the group code is an integer it has a restype of
AcDb::kDxfXdInteger16 (group code 1070).
The second resbuf in each pair is the value for that dimvar. Data values for
dimvars may be strings, integers, reals, or objectIds. As with resbufs in
general, the value of the resbuf’s restype indicates how to read the data in the
resval. Please refer to the Table below.
As an example, here is a dimension style override list that will override the
DIMTAD and DIMGAP variables. The list is shown in AutoLISP format with indenting
for clarity.
("ACAD"
(1000 . "DSTYLE")
(1002 . "{")
(1070 . 77) (1070 . 1)
(1070 . 147) (1040 . 0.2)
(1002 . "}")
In this example the group code 77 is DIMTAD, which is overridden to be 1. Then
DIMGAP (group code 147) is set to 0.2.
The following code sample uses acutBuildList() to create this resbuf chain and
to set overrides for DIMTAD and DIMGAP on the entity pointed to by pEnt,
assuming pEnt points to an AcDbEntity of one of the types listed above and is
open for writing:
resbuf* pRb = acutBuildList(
AcDb::kDxfRegAppName, "ACAD",
AcDb::kDxfXdAsciiString, "DSTYLE",
AcDb::kDxfXdControlString, "{",
AcDb::kDxfXdInteger16, 77, AcDb::kDxfXdInteger16, 1,
AcDb::kDxfXdInteger16, 147, AcDb::kDxfXdReal, 0.2,
AcDb::kDxfXdControlString, "}",
RTNONE);
Acad::ErrorStatus es = pEnt->setXdata(pRb);
acutRelRb(pRb);
It is very important the xdata you set onto an object have the proper sequence
of resbufs. Each override must have both the DXF group code resbuf and the
associated value resbuf. In addition, the value must be the correct data type
(string, real, or int) and must be within the allowable range for that dimvar.
If any of these conditions are not met, AutoCAD may terminate. Also, the 1000
"DSTYLE" and the following 1002 "{" "}" set must be present, and there must only
be one set of all of these.
Remember that xdata is obtained and replaced on a per-appId basis. To modify any
dimension overrides, work with the complete list of xdata for the "ACAD" appId,
which may have other data, including other dimension overrides. So, be sure to
obtain whatever xdata may already be present for the "ACAD" appId (use the
object's xData() method with the string "ACAD"). Add or remove only the
dimension override information you need, making sure that if dimension override
information already exists you don't duplicate any of the xdata that's already
there (including the "DSTYLE" string and the 1002 "{" "}" bracket pairs). Place
new overrides in between the existing 1002 bracket pair, and put the complete
modified list back into the object via the object's setXData() method. If not
done correctly, AutoCAD may terminate.
Here is a table of all the DimStyleTableRecord dimvars, with their DXF group
codes, data types, and value ranges:
Group code Dimension variable Data type Value range
3 DIMPOST string any
4 DIMAPOST string any
40 DIMSCALE real >= 0.0
41 DIMASZ real >= 0.0
42 DIMEXO real >= 0.0
43 DIMDLI real >= 0.0
44 DIMEXE real >= 0.0
45 DIMRND real >= 0.0
46 DIMDLE real >= 0.0
47 DIMTP real >= 0.0
48 DIMTM real >= 0.0
49 DIMFXL real any value new 2007
50 DIMJOGANG real 0.08727 - 1.5708 new 2007 (5 - 90 degrees)
69 DIMTFILL int 0 - 2 new 2007
70 DIMTFILLCLR int 0 - 256 new 2007
71 DIMTOL int 0 = off, 1 = on
72 DIMLIM int 0 = off, 1 = on
73 DIMTIH int 0 = off, 1 = on
74 DIMTOH int 0 = off, 1 = on
75 DIMSE1 int 0 = off, 1 = on
76 DIMSE2 int 0 = off, 1 = on
77 DIMTAD int 0 - 3
78 DIMZIN int 0 - 15
79 DIMAZIN int 0 - 15 new
90 DIMARCSYM int 0 - 2 new 2007
140 DIMTXT real >= 0.0
141 DIMCEN real any value
142 DIMTSZ real >= 0.0
143 DIMALTF real >= 0.0
144 DIMLFAC real >= 0.0
145 DIMTVP real >= 0.0
146 DIMTFAC real >= 0.0
147 DIMGAP real any value
148 DIMALTRND real >= 0.0 new
170 DIMALT int 0 = off, 1 = on
171 DIMALTD int >= 0
172 DIMTOFL int 0 = off, 1 = on
173 DIMSAH int 0 = off, 1 = on
174 DIMTIX int 0 = off, 1 = on
175 DIMSOXD int 0 = off, 1 = on
176 DIMCLRD int 0 - 256
177 DIMCLRE int 0 - 256
178 DIMCLRT int 0 - 256
179 DIMADEC int 0 - 8 new
271 DIMDEC int 0 - 8
272 DIMTDEC int 0 - 8
273 DIMALTU int 1 - 8
274 DIMALTTD int 0 - 8
275 DIMAUNIT int 0 - 4
276 DIMFRAC int 0 - 2 new
277 DIMLUNIT int 0 - 4 new
278 DIMDSEP int (char) any char new
279 DIMTMOVE int 0 - 2 new
280 DIMJUST int 0 - 4
281 DIMSD1 int 0 = off, 1 = on
282 DIMSD2 int 0 = off, 1 = on
283 DIMTOLJ int 0 - 2
284 DIMTZIN int 0 - 15
285 DIMALTZ int 0 - 15
286 DIMALTTZ int 0 - 15
288 DIMUPT int 0 = off, 1 = on
289 DIMATFIT int 0 - 3 new
290 DIMFXLON int 0 = off, 1 = on new 2007
294 DIMTXTDIRECTION int 0 = off, 1 = on new 2007
340 DIMTXSTY objectId new
341 DIMLDRBLK objectId new
342 DIMBLK objectId new
343 DIMBLK1 objectId new
344 DIMBLK2 objectId new
345 DIMLTYPE objectId new 2007
346 DIMLTEX1 objectId new 2007
347 DIMLTEX2 objectId new 2007
371 DIMLWD int lineweights new
372 DIMLWE int lineweights new
