Author Topic: making Tony T's Commandline code work for Bricscad  (Read 1844 times)
jmaeding
  • I'm just here for the Shelties.
« on: August 28, 2013, 01:30:53 PM »
In his well known code to send commands to the cmd line, the code starts like this:
public static int Command(params object[] args) {
      if (AcAp.DocumentManager.IsApplicationContext)
        return 0;
      int stat = 0;
      int cnt = 0;
Bricscad's .net api does not have the IsApplicationContext property for DocumentManager.
From what I read, this is not trivial.
Are there other ideas on how to check if the command line is ready for input?
James Maeding
BillZndl
Re: making Tony T's Commandline code work for Bricscad
« Reply #1 on: August 28, 2013, 02:40:17 PM »
Maybe?
if (AcadApp.IsQuiescent)
                try
                    OpenGroupCommandDialog.CallGroupCommand();
snip from some code I use.
