Posted an incomplete code at post #1..I proceeded to follow the pseudo code on post # 2 just i could put together a working solution [not that its complete
![Laughing my *beep* off :lmao:](http://www.theswamp.org/Smileys/black/laugh.gif)
Like a person would normally solve a jigsaw puzzle, Start with corners. do the edge and the middle last.
I will try to shorten the code as soon as i done.
Lee. I finally got the chance to try your code, I'm still at awe how were you able to write the code with very few lines. [how did you manage that?]
I notice there are four pieces although connected to each other did not position itself correctly on the board. or is it just me.
Still dissecting your code as of this writing..... [and you call it terrible coding.
![Grin ;D](http://www.theswamp.org/Smileys/black/grin.gif)
that would make mine as Horrible then
Marko.
I didn't realized or read your fist post thoroughly, but it appears that code only highlight the corner pieces but doesn't really placed it on the board
Based on the number of lines on your code I'm sure you have something up your sleeve and the code is just a tease
My code and LMs' code might work on your drawing attachment if there are no other straight [Vertical/Horizontal] lines inside your jigsaw board. You know like an ordinary jigsaw puzzle you buy on wall-mart.Cheers
