Author Topic: How to use "Trustedpaths"  (Read 2614 times)
MeasureUp
« on: June 13, 2013, 09:13:07 PM »
I just upgraded to v2014.
How to add a trusted path by using "trustedpaths"?
Will this remove all existing trusted paths?
I am a bit scared before adding a trusted path.
(setvar "trustedpaths" "S:\My Lisps")
And how to show the entire list of trusted paths?
It returns the following when entered "trustedpaths" in the command line.
Command: TRUSTEDPATHS
Enter new value for TRUSTEDPATHS, or . for none <"C:\Program Files\Autodesk\AutoCAD 2014\acadm;C:\Program File...">:
Thanks for your helps.
WILL HATCH
Re: How to use "Trustedpaths"
« Reply #1 on: June 13, 2013, 09:46:19 PM »
looks like you should concatenate the old value with the new to avoid overwriting.  Me no speaka da lispy too gooder but something like:
(setvar "trustedpaths" (strcat (getvar "trustedpaths") ";S:\My Lisps")
huiz
  • Certified Prof C3D
« Reply #2 on: June 14, 2013, 02:57:09 AM »
You can also turn off the check for trusted paths.
MeasureUp
« Reply #3 on: June 14, 2013, 03:02:34 AM »
andrew_nao
« Reply #4 on: June 14, 2013, 08:50:25 AM »
yes it will overwrite the trustedpath of what you had there originally
check out this topic for some code and info on trustedpaths
http://www.theswamp.org/index.php?topic=44322.0
check these out also
http://docs.autodesk.com/ACD/2014/ENU/index.html?url=files/GUID-9C7E997D-28F8-4605-8583-09606610F26D.htm,topicNumber=d30e104239
http://docs.autodesk.com/ACD/2014/ENU/files/GUID-C6DCBFE5-25F6-4387-BD02-B021FA06E3FD.htm
