Author Topic: Problem with Autocad 2014 on opening  (Read 1827 times)
Coder
« on: June 04, 2013, 04:16:34 AM »
Hello Guys .
I have a problem with Autocad 2014 , when I open a drawing and go back to the first drawing it would be unavailable until I regen the drawing and even if I started new drawing .
Did anyone face this problem before ?
The problem is so confusing , is there any system variable related to this one ?
Thanks in advance .
huiz
  • Certified Prof C3D
Re: Problem with Autocad 2014 on opening
« Reply #1 on: June 04, 2013, 07:35:02 AM »
No problems here. I can create and open multiple drawings and all are accessable.
Maybe something with variables as TASKBAR (set to 1)? Or SDI?
Coder
« Reply #2 on: June 04, 2013, 08:53:37 AM »
Hi .
The problem is not with multiple drawing but when I open a drawing and go back to the previous drawing I need to regen to see the objects in the drawing .
