Author Topic: [C3D 2012] - Enhanced reference audit problems for database  (Read 2743 times)
Matt__W
  • I like my water diluted.
I just cracked open a drawing that has data shortcuts (it's a construction drawing for profiles) and saw a whole bunch of these...
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [5E664], Broken reference, Remove
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [5E7B4], Broken reference, Remove
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [5E7B9], Broken reference, Remove
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [5E7BE], Broken reference, Remove
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [5E7DD], Broken reference, Remove
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [5E803], Broken reference, Remove
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [5E808], Broken reference, Remove
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [5E882], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [5E7B1], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [5E7B6], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [5E7BB], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [5E7DA], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [5E800], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [5E805], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [5E87F], Broken reference, Remove
AECC_VALIGNMENT_PVI_LABEL_GROUP [5E662], Broken reference, Remove
AECC_VALIGNMENT_PVI_LABEL_GROUP [5E7B2], Broken reference, Remove
First, what does it mean?  It doesn't look good so just how bad is it?  And how do I go about fixing (or removing) the messages?
Autodesk Expert Elite
Jeff_M
  • C3D user & customizer
Re: [C3D 2012] - Enhanced reference audit problems for database
« Reply #1 on: May 16, 2013, 10:07:58 AM »
That means the referenced object could not be resolved, so the profile cannot be rendered, so the labels have nothing to be attached to, so they are removed from the drawing. Which is usually not a good thing. You need to fix the shortcut so it can be found, before opening that drawing.
« Reply #2 on: May 17, 2013, 09:54:31 AM »
someone moved or renamed a file...hope you can find it
