Serpentine block walls
Here's 1 I'm up against:
This could be brick, CMU or glass tile like shown:
The MEASURE command really sucks when it comes aligning a block along a serpentine path
Rules ( in this case )
- The glass tile is 6 Wide x 6 High x 4 Thick - GLSB-664
- Horizontal grout joint : consistent 0.4 thick
- Vertical grout joints : Inside Radius of the curve : Minimum Width 0.2 Outside Radius of the curve : No Maximum Width
The BLOCK GLSB-664 has the horizontal grout joints built into it ( 6.40 high )
It has no vertical joints at all. It would be arrayed @ 6.4 along a straight path
So how to calculate the INSERT points and angles from a curved path. In the real world, the first and last blocks will probably be a short straight segment, then start the curve.
I will probably extrapolate the vertical joint points from the INSERT data.
Any ideas? Thanks -David
