Author Topic: sending email via acad  (Read 3843 times)
andrew_nao
« on: March 18, 2013, 11:41:43 AM »
trying to send email via acad and my outlook get a popup saying "a program is
trying to send email do i want to allow or deny it.."
has anyone else gotten this message and is there a way to get around it?
im using outlook 2007
here is the code im using
(defun email ()
         (setq olApp (vlax-get-or-create-object "Outlook.Application"))
         (setq objMail (vlax-invoke olApp 'CreateItem 0))
         (vlax-put-property objMail 'Subject "testing")
         (vlax-put-property objMail 'To "test email@test.com")
         (vlax-put-property objMail 'Body "testing")
         (vlax-invoke objMail 'Send)
Re: sending email via acad
« Reply #1 on: March 18, 2013, 11:51:12 AM »
There was not an answer when you asked back in 2010 ? I would think it's related to a security setting.
http://www.theswamp.org/index.php?topic=36083.msg412060#msg412060
« Last Edit: March 18, 2013, 11:54:16 AM by ronjonp »
« Reply #2 on: March 18, 2013, 11:55:23 AM »
You have a long memory grasshopper.  :lol:
« Reply #3 on: March 18, 2013, 11:57:51 AM »
 :-D If only that were true...
andrew_nao
« Reply #4 on: March 18, 2013, 12:02:48 PM »
i think it might have something to do with
(vlax-put objMail 'FlagRequest "1")
but when i enter this code or any other code in, line by line manually on the command line, i get nil for my return response.
andrew_nao
« Reply #5 on: March 18, 2013, 12:05:12 PM »
ahh there is the post... i couldnt find it, i knew i asked before.
and in 3 years i have no solution... :(
andrew_nao
« Reply #6 on: March 18, 2013, 12:12:57 PM »
If your computer is managed by a Microsoft Exchange administrator or a Microsoft Windows Active Directory Domain Services administrator in your organization, and the administrator changes the default setting and prevents users from making changes, the option to customize the Programmatic Access security settings will be disabled.
If your computer is not managed by an Exchange administrator or a Microsoft Windows Active Directory Domain Services administrator, and you are the Windows administrator of your computer, you can change the Programmatic Access security settings. However, this is not recommended.
the answer to my question
thanks for the replys
Patrick_35
« Reply #7 on: March 18, 2013, 12:58:19 PM »
Hi
And with "CDO.Message" ?
For example
(setq Outlk (vlax-Create-Object "CDO.Message"))
(setq Serv (vlax-Get-Property (vlax-Get-Property Outlk 'Configuration) 'Fields))
(vlax-Put-Property (vlax-Get-Property Serv 'Item "http://schemas.microsoft.com/cdo/configuration/sendusing")      'Value 2)
(vlax-Put-Property (vlax-Get-Property Serv 'Item "http://schemas.microsoft.com/cdo/configuration/smtpserver")     'Value "ServerSMTP") ; ex: smpt.aol.com
(vlax-Put-Property (vlax-Get-Property Serv 'Item "http://schemas.microsoft.com/cdo/configuration/smtpserverport") 'Value 25)
(vlax-Invoke Serv 'Update)
(vlax-Put-Property Outlk 'From     "My_email@server.com")
(vlax-Put-Property Outlk 'To       "Recipient@server.com")
(vlax-Put-Property Outlk 'Subject  "Subject")
(vlax-Put-Property Outlk 'TextBody "My Message")
(vlax-invoke outlk 'AddAttachment "My_Text.txt")
(if (vl-catch-all-error-p (vl-catch-all-apply 'vlax-invoke (list outlk 'Send)))
  (princ "\nImpossible to send the message. No connection Internet")
(vlax-Release-Object Outlk)
andrew_nao
« Reply #8 on: March 18, 2013, 01:19:12 PM »
Hi
For example
still wont work, the error message kicks in
thanks though
BlackBox
« Reply #9 on: March 18, 2013, 01:20:55 PM »
FWIW... I got around this issue by upgrading to Office 2010... Not sure if that option is available to you, but it works.  :-)
irneb
« Reply #10 on: March 19, 2013, 01:44:13 AM »
You could of course use something like a command-line emailing client: http://www.techsupportalert.com/content/send-email-windows-command-line.htm
