Author Topic: is there a was to read vla objects?  (Read 1221 times)
andrew_nao
« on: March 05, 2013, 02:51:17 PM »
if you goti a variable like so
#<VLA-OBJECT _Application 0000000038f4a688>
is there a way to see whats "inside" of it
like how you can see the dxf codes inside a selection set?
dgorsman
Re: is there a was to read vla objects?
« Reply #1 on: March 05, 2013, 02:52:45 PM »
Take a dump   ^-^ :  (vlax-dump-object ...).  There's a second argument which controls whether available methods are shown as well.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
andrew_nao
« Reply #2 on: March 05, 2013, 03:04:31 PM »
thanks
nobody
  • .net stuff
« Reply #3 on: March 06, 2013, 06:49:41 AM »
lol
David Hall
  • Automatic Duh Generator
« Reply #4 on: March 06, 2013, 08:53:43 AM »
With regard to that, when you get the results, depending on what your doing you may have to interpolate the result.  As an example, Lee posted some code for selecting a particular object, which when I dumped the object, it was AcDbText.  Lee's routine was looking for the type, which turned out to be "Text" (DXF code 0).
