Author Topic: Units seem to be locked on FEET, help.  (Read 1958 times)
Andrew H
« on: March 15, 2005, 03:14:56 PM »
Ok, I received a drawing from an Architect in Mexico. The drawing is drawn in METERS, but the UNITS are set to FEET. I go in an change the units to meters work on the draw and save. Close and reopen the drawing and the units are back in Feet, what gives?
PDJ
« Reply #1 on: March 15, 2005, 03:45:09 PM »
Are you using anything like Architectural or Land Development Desktop?  Those programs have a setting that will revert back to what they were set as when you first start the drawing.  Drove me nuts for a couple days trying to figure that one out..
Andrew H
« Reply #2 on: March 15, 2005, 03:50:08 PM »
Nope Vanilla AutoCAD (2005).
MikePerry
« Reply #3 on: March 16, 2005, 05:29:52 AM »
Hi
Did the architect use ADT or LDT (or has the drawing ever been worked on in an Autodesk vertical product)?
If yes, the following Technical Documents might shed some light on the problem -
ID: TS66008 - Skip Main Content and go to Footer Contents.Drawing settings are overridden
ID: TS65039 - AutoCADŽ units or dimension scale is automatically overridden
ID: TS65525 - AutoCAD Drawing Units revert to decimal values
ID: TS53217 - Settings for units are not retained
ID: TS74732 - AutoCAD units precision changes without warning
Have a good one, Mike
Andrew H
« Reply #4 on: March 16, 2005, 09:34:51 AM »
Thanks for the info.
So, if the architect is using ADT or LDT, i'm SOL?
Andrew H
« Reply #5 on: March 16, 2005, 09:38:44 AM »
1. From the Tools menu, choose Options.
2. In the Options dialog box, select the Open and Save tab.
3. In the ObjectARX Applications settings, set the Demand Load ObjectARX Apps value to Command Invoke and choose OK.
The above steps worked. Thanks.
