Author Topic: VBA Function not working in AutoCAD 2013  (Read 3669 times)
Tyke
« on: February 22, 2013, 11:50:13 AM »
I have a VBA module and a function in it which basically just creates a group. The function works fine on all AutoCAD versions 2008 to 2012, but in AutoCAD 2013 it crashes with an error message "Run time error '-2147417856 (800 10 100)".
Here's the function:
Public Function CreateGroup(grpName As String) As AcadGroup
    Dim colGroups As AcadGroups
    Dim objGroup As AcadGroup
    Set colGroups = ThisDrawing.Groups
    On Error Resume Next
    Set objGroup = ThisDrawing.Groups.Item(grpName)
    ' create the group
    If Not objGroup Is Nothing Then
        objGroup.Delete
    End If
    Set objGroup = ThisDrawing.Groups.Add(grpName)
    ' check if it was created
    If objGroup Is Nothing Then
        MsgBox "Unable to Add '" & grpName & "'"
    End If
End Function
When I go into debug mode it stops on:
I tested it on two computers with the same results on both. It would appear to be a problem with 2013.
Has anyone else encountered this problem?
