Author Topic: Make a block un-purgable?  (Read 11542 times)
roy_043
  • BricsCAD 18
« on: February 21, 2013, 08:37:06 AM »
Apart from inserting a reference (on a frozen layer) somewhere, is there a way to make a 'normal' fixed block un-purgable? Note: I am using BricsCAD.
huiz
  • Certified Prof C3D
Re: Make a block un-purgable?
« Reply #1 on: February 21, 2013, 08:50:29 AM »
Only if it is used in some way. Like on a frozen layer, on a layout, or as marker in an used dimstyle.
But if one really needs to strip the block, there is nothing to do about.
Drafter X
« Reply #2 on: February 21, 2013, 08:54:58 AM »
make it invisible
CadJockey Militia Commander
dgorsman
« Reply #3 on: February 21, 2013, 12:16:09 PM »
make it invisible
Ugh, please NO.  Along with making the block attribute only with the attributes hidden, or making it dynamic with a visibility state with all graphics turned off, blocks that cannot be found follow the "out of sight, out of mind" principle.  They accumulate and before you know it, your drawings (and blocks) have thousands of inserts.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
fixo
« Reply #4 on: February 21, 2013, 12:28:12 PM »
perhaps to add xdata to this block definition, just an idea
« Reply #5 on: February 21, 2013, 12:31:16 PM »
As far as I was aware, to make an object truly 'unpurgable', you need to use a hard reference, however, I don't believe such a reference can be created using AutoLISP / Visual LISP.
trogg
« Reply #6 on: February 21, 2013, 04:03:42 PM »
What about this?: http://www.theswamp.org/index.php?topic=10978.msg139130#msg139130
We used it in a "seed" file at work instead of using a template to make a text and dim style available. It worked quite well.
(we used the routine provided by madcadder)
~Greg
kruuger
« Reply #7 on: February 21, 2013, 06:09:42 PM »
if you have a company title block border in your drawing (for example at layout) just add your block to border with small scale x=y=z=0.00001
Referring to trogg link. try to delete layers from this drawing (small puzzle autocad)  ;)
k.
« Reply #8 on: February 21, 2013, 06:24:39 PM »
 :-P
kruuger
« Reply #9 on: February 21, 2013, 06:36:09 PM »
:P
i should rather say, try to purge. :|
what option/lisp to clean dwg ?
k.
« Reply #10 on: February 21, 2013, 07:25:26 PM »
:P
k.
This is what I use:
(defun c:wba ( / dwg fnm tmp )
    (setq fnm
        (strcat
            (getvar 'dwgprefix)
            (cadr (fnsplitl (getvar 'dwgname)))
            "_wblock"
    (if (findfile (setq dwg (strcat fnm ".dwg")))
            (setq tmp 1)
            (while (findfile (setq dwg (strcat fnm "(" (itoa (setq tmp (1+ tmp))) ").dwg"))))
    (command "_.wblock" dwg "*")
« Reply #11 on: February 21, 2013, 08:12:41 PM »
Try to delete layers from this drawing (small puzzle autocad)  ;)
Look what I found  :wink:
(mapcar 'print (entget (handent "9C28")))
Layers purgable after:
(dictremove (cdr (assoc 360 (entget (cdr (assoc 330 (entget (tblobjname "LAYER" "0"))))))) "JCAD_LAYERS")
Fun puzzle :-)
« Last Edit: February 21, 2013, 08:18:21 PM by Lee Mac »
Jeff H
« Reply #12 on: February 21, 2013, 08:25:08 PM »
Not sure how to do it in lisp but very easy in .Net or ObjectARX,
You can add a entry to the NamedObjectDictionary, or the ExtensionDictionary of ModelSpace, etc..(Something that will always be in a drawing and never removed like ModelSpace) with the ObjectId of the BlockTableRecord and with a HardPointerObjectId typecode(340).
kruuger
« Reply #13 on: February 22, 2013, 01:53:57 AM »
yep  :)
kruuger
Marc'Antonio Alessi
  • Marco
« Reply #14 on: February 22, 2013, 05:51:16 AM »
This is what I use:
    (setq fnm
        (strcat
            (getvar 'dwgprefix)
            "_wblock"
            (setq tmp 1)
Try to purge this.
