Author Topic: SendCommand() with "insert" string during transaction  (Read 2028 times)
bchapman
« on: February 10, 2013, 02:41:20 AM »
Can the SendCommand() with "insert" as string/command be used during a transaction? I need to insert a block during a transaction...and want to use the SendCommand() to do it.
Thanks!
gile
  • Marseille, France
Re: SendCommand() with "insert" string during transaction
« Reply #1 on: February 10, 2013, 05:00:05 AM »
Yes, you can.
But SendCommand() should be asynchronous (it will excute after all "hard coded" modifications to the drawing).
If you want to call an AutoCAD built-in command synchronously you'd have to P/Invoke the unmanaged acedInvoke() method or call the non-public RunCommand() method.
The other route (which I tended to follow while I used LISP, and tend to continue following since I started learning .NET) is to avoid calling AutoCAD built-in commands. You'd find many post showing how to insert a block reference here at TheSwamp:
.NET BLOCK Routines
BlockTesting2011
bchapman
« Reply #2 on: February 10, 2013, 05:14:15 AM »
Thank you very much! :)  Very helpful
TheMaster
« Reply #3 on: February 10, 2013, 04:22:25 PM »
Thanks!
Take Gile's advice. Trying to mix the command line interface with transactions is asking for trouble. In fact, if I'm not mistaken, starting or ending commands while a transaction is active would probably crash AutoCAD.
bchapman
« Reply #4 on: February 10, 2013, 09:44:33 PM »
Thanks TT. I have...  I was fighting with using the SendCommand() so much I gave up. Inserting blocks with attributes will be a part of so many routines I'm re-writing from my lisp library that I figured I need to figure it out. I'm going over all the data he sent.
