Author Topic: ACI color drawing  (Read 9406 times)
Jeff H
ACI color drawing
« on: February 07, 2013, 10:11:45 AM »
Started creating a drawing to print out to visually see what a .ctb plotstyle looked like for the ACI colors, and still needs some cleaning up but thought some people could maybe modify it to suit their needs.
I copied parts from ColorWheel drawing Autodesk put out so some things on layers that do not make since but could add table with lineweights and annotate different lineweights your company use.
The drawing is attached
Rob...
Re: ACI color drawing
« Reply #1 on: February 07, 2013, 10:14:27 AM »
Thank you.
CAD Tech
« Reply #2 on: February 07, 2013, 10:26:16 AM »
Thanks.
BlackBox
« Reply #3 on: February 07, 2013, 01:23:32 PM »
Thanks, Jeff.
We used to use one that provided Standard color, and true color numbers, pen weight (it was for CTB) / % screen, and also had some lines/hatch as sample... I'll have to see if I can find the source DWG. Snippet of PDF attached:
Jeff H
« Reply #4 on: February 07, 2013, 05:18:04 PM »
Renderman,
That one does look much nicer and would be great to throw in the toolbox.
BlackBox
« Reply #5 on: February 07, 2013, 05:22:34 PM »
Renderman,
I'll see if I can track it (the DWG) down... Will post back when I find/recreate.  :lol:
Drafter X
« Reply #6 on: February 08, 2013, 01:11:13 PM »
please, and would you mind if I used it to provide a plotted wieght vs color sample with it?
CadJockey Militia Commander
BlackBox
« Reply #7 on: February 08, 2013, 02:24:39 PM »
It's funny you should ask... When recreating this (I couldn't locate the source DWG from 2008, when we deployed LDC 2009), I had already added that:
« Last Edit: April 11, 2016, 07:59:44 PM by BlackBox »
Jeff H
« Reply #8 on: February 08, 2013, 07:45:26 PM »
Thanks Renderman!!!!
I didn't mean for you to recreate it, but glad that you did.
Thanks again!
BlackBox
« Reply #9 on: February 08, 2013, 11:19:58 PM »
Happy to help... I usually print a PDF of each plot style used, and a have small LISP routine to open the PDF based on the Layout Objects current Plot Style. Very handy when switching between legacy, current, and client standards.
I'll post that next week when I'm back at my computer.
Drafter X
« Reply #10 on: February 12, 2013, 11:07:17 AM »
 :kewl:  Indeed, that rocks, thankee
gherrman
  • Mosquito
« Reply #11 on: November 23, 2020, 12:44:43 PM »
Could you post the associated .ctb file, presumably "WM_STD-02R.ctb"?
