Author Topic: help! groups?  (Read 2224 times)
Q1241274614
help! groups?
« on: February 05, 2013, 11:36:57 PM »
1 ssget
2 elements in 3
« Last Edit: February 06, 2013, 08:09:09 AM by Q1241274614 »
Tharwat
  • Hypersensitive
Re: groups
« Reply #1 on: February 05, 2013, 11:42:54 PM »
Is this a puzzle ?
irneb
Re: groups
« Reply #2 on: February 05, 2013, 11:59:07 PM »
If you mean that selecting one item gives a selection set of 3 items, that's because they've been grouped and your group selection is turned on. Try adjusting PickStyle:
http://docs.autodesk.com/ARCHDESK/2013/ENU/index.html?url=filesACD/GUID-C20C24AD-81F5-4E4A-A414-B1A2BC71E041.htm,topicNumber=ACDd30e201157
Q1241274614
Re: groups
« Reply #3 on: February 06, 2013, 05:39:44 AM »
(DEFUN C:TT()
  (setq p (getpoint "\n起点 "))
  (setq q (getpoint p "\n终点点 "))
  (setq r1 (getdist "\n起点半径"))
  (setq r2 (getdist "\n起点半径"))
  (setq l1(entmakex (list (cons 0 "LINE") (cons 10 p)(cons 11 q)(cons 62 2))))
  (setq er1(entmakex (list (cons 0 "CIRCLE") (cons 10 p) (cons 40 r1)(cons 62 4))))
  (setq er2(entmakex (list (cons 0 "CIRCLE") (cons 10 q) (cons 40 r2)(cons 62 4))))
  (vlax-ldata-put l1 "规格" (strcat "l1="(rtos (distance p q) 2 0)))
  (vlax-ldata-put er1 "规格" (strcat "r1=" (rtos r1 2 0)))
  (vlax-ldata-put er2 "规格" (strcat "r2="(rtos r2 2 0)))
Excuse me what method can be the same length as the radius of the circle line, the same as a group of selected objects! Contains: copy,
« Last Edit: February 06, 2013, 05:44:17 AM by Q1241274614 »
Re: help! groups?
« Reply #4 on: February 06, 2013, 08:30:00 AM »
This is the Chicken or the egg riddle.  8-)
Select objects & build a table
OR
Select the table & build the objects
Re: help! groups?
« Reply #5 on: February 06, 2013, 08:36:09 AM »
Select objects and build table?
(defun c:test ( / en in l1 l2 l3 l4 ss x1 x3 x4 )
    (if (setq ss (ssget '((0 . "LINE,CIRCLE"))))
            (repeat (setq in (sslength ss))
                (setq en (entget (ssname ss (setq in (1- in)))))
                (if (= "LINE" (cdr (assoc 0 en)))
                    (setq l1 (cons (list (cdr (assoc 10 en)) (cdr (assoc 11 en))) l1))
                    (setq l2 (cons (list (cdr (assoc 10 en)) (cdr (assoc 40 en))) l2))
            (while (and l1 l2)
                (setq x1 (car l1)
                      l1 (cdr l1)
                      l3 nil
                (foreach x2 l2
                    (if (and (not (cddr l3))
                            (or (equal (car x2) (car  x1) 1e-8)
                                (equal (car x2) (cadr x1) 1e-8)
                        (setq l3 (cons (cadr x2) l3)
                              l2 (vl-remove x2 l2)
                (if l3
                    (if (setq x4 (assoc (setq x3 (cons (apply 'distance x1) (vl-sort l3 '<))) l4))
                        (setq l4 (subst (list x3 (1+ (cadr x4))) x4 l4))
                        (setq l4 (cons  (list x3 1) l4))
            (mapcar 'print l4)
Q1241274614
Re: help! groups?
« Reply #6 on: February 06, 2013, 10:29:59 PM »
Thanks Lee for your explanation.
Q1241274614
Re: help! groups?
« Reply #7 on: February 08, 2013, 12:06:03 AM »
What can be achieved by ( vlax-ldata-put ) statistics, because some elements not necessarily at the line end.
