Author Topic: ft or inches  (Read 4374 times)
daron
ft or inches
« on: March 14, 2005, 12:58:04 PM »
I just can't think of how to do this:
I want to ask a user for an input of a number and allow them to supply inches or feet and have lisp know the difference. I just can't think of how to do it. Anybody got any ideas. Seems like it shouldn't be too hard.
ft or inches
« Reply #1 on: March 14, 2005, 01:03:17 PM »
Use getstring and then distof.
ft or inches
« Reply #2 on: March 14, 2005, 01:09:11 PM »
Use the getdist function.
daron
ft or inches
« Reply #3 on: March 14, 2005, 01:19:02 PM »
Thank you.
ft or inches
« Reply #4 on: March 14, 2005, 01:19:46 PM »
Hey Charles, try this --
(setvar "lunits" 2)
(getdist) [enter] 12' [enter]
*shladdap*, rake in the face. :(
Subtitle: Getdist's ability to accept keyed input is a function of the lunits sys var setting.
daron
ft or inches
« Reply #5 on: March 14, 2005, 01:23:52 PM »
CAB, that is what I was looking for. I knew it was there, I just needed to try it. Of course, I'll have to take MP's above thought to test.
ft or inches
« Reply #6 on: March 14, 2005, 02:04:39 PM »
Quote from: MP
(setvar "lunits" 2)
Why would you press [enter] before your 12'?
What happens with
(getstring) [enter] 12' [enter] :)
I was thinking getdist because it will allow many format options for user input.
daron
ft or inches
« Reply #7 on: March 14, 2005, 02:48:34 PM »
Here's the solution to MP's problem:
(if (or (< (getvar 'lunits) 3) (> (getvar 'lunits) 4))
    (setq lunitnum (getvar 'lunits))
    (setvar 'lunits 4)
(setq height (getdist "\nHeight of Wall: "))
(setvar 'lunits lunitnum)
Note: Any value other than 3 or 4 will result in the inability to use the ft (') mark.
ft or inches
« Reply #8 on: March 14, 2005, 02:59:11 PM »
Oh, I see now. The fog is starting to lift.
Sorry Michael, as usual your reply went right over my pointy little head. :oops:
ft or inches
« Reply #9 on: March 14, 2005, 03:17:27 PM »
No worries Charles. You correctly pointed out the use of getdist; I just pointed out one mustn't make assumptions about its behavior. :)
And now for something completely different:
(defun distanceof ( x  / result )
    (vl-catch-all-apply
       '(lambda ()
            (vl-some
               '(lambda (units) (setq result (distof x units)))
                (list (getvar "lunits") 4 5 2 1)
    result
ft or inches
« Reply #10 on: March 14, 2005, 03:43:03 PM »
That's is a thing of beauty Michael.
ft or inches
« Reply #11 on: March 14, 2005, 04:17:39 PM »
Thank you Mark, meant to be (primarilly) demonstrative. :)
