I have sucessfully implemented functionality which extends the event handlers for various actions, but have come to screeching halt on the following scenario:
Extend doubleclick handler at document load to persistently run an entity filtering mechanism
Test double-clicked entity, filtering by entity type and XData name and values
If specific filter passes muster, route entity to a specific custom command
If entity passes through, simply revert to AutoCADs native doubleclick handler (or do nothing, depending on state of DBLCLKEDIT)
We have been doing this using VBA to trap the pickfirst entity, custom filter and route, or drop back to using the appropriate SendCommand:
ElseIf TypeOf entity Is AcadTable Then
ThisDrawing.SendCommand "_.TABLEDIT "
ElseIf TypeOf entity Is AcadPViewport Then
ThisDrawing.SendCommand "_.VPMAX "
ElseIf TypeOf entity Is AcadOle Then
ThisDrawing.SendCommand "_.OLEOPEN "
...etc, testing for everything, yikes.
As we migrate more of our commands away from VBA (yay!) and build more fresh .NET widgets, we would really like to maintain this ease of editing our quasi-custom entities.
Additionally, the VBA code occasionally blows up when switching drawings in a 64-bit environment, but I haven't had time to dig deeper on that one.
Clues, direction? Thanks
